The Bessler Wheel, mystery solved.
Started by gurangax, April 24, 2014, 02:40:13 PM
AquariuZ
Quote from: LibreEnergia on June 08, 2014, 09:29:11 PM
It's not worth even trying.
The closest any wheel can become to being "over-unity" is when it is perfectly balanced with a bearing of the lowest possible friction and spinning in a vacuum..
Obviously this configuration is NOT over-unity, but one thing is certain, any other configuration that involves moving weights around during a cycle will be less efficient.
Creating an overbalanced condition requires energy. At best we can recover the some but not all of that energy as the wheel rotates. Since all movement involves frictional losses we would improve efficiency by having less movement of parts relative to each other. Take this to the logical conclusion and you end up back at the perfectly balanced wheel.
I hear that. You need input to create imbalance. But it also seems to me the levers are at least part of Besslers' idea.
Do you believe Bessler had a gravity wheel or not?
AZ
MarkE
Quote from: AquariuZ on June 08, 2014, 06:54:17 PM
If I may come to the defense of the Gurangax simple but elegant idea.
I have taken HIS model - simplified it and now show a 3 : 1 ratio lift AND hold of a weight towards the wheel perimeter. I have also added some comments to the model (attached) which are:
I can imagine a large wheel with crossbars like the one pictured on the left and the crossbar weights on the perimeter of the wheel were the pendulums are close to but do not  touch the outer perimeter.
Gravity pulls the pendulums which pushes and holds the crossbars weights towards the wheel perimeter long enough to create an imbalance which will make the wheel rotate.
It will rotate either way and it will be permanently unbalanced. The correctly positioned pendulum lever will give a 3:1 lift ratio. Tuning needed for desired RPM.
Definitely worth a try.
200% weight leverage is nothing to joke about. Look at the potential energy readings in the model. Yes, there be friction mateys, but still worth a try.
Thank you very much Gurangax for publishing this - very interesting. I would advise contacting Preston Stroud if you would like a good builder on your team.
AZ
The problem with things like levers is that with force multiplication comes distance division and the energy remains in balance.
MarkE
Quote from: AquariuZ on June 08, 2014, 09:40:32 PM
AZ
I for one do not believe Bessler's claims.
Airstriker
Quote from: AquariuZ on June 08, 2014, 08:52:00 PM
Ok real quick.
Try one:
Two lever pendulums of 1.5 KG each pushing a 9KG weight towards the perimeter at the 12, 1, 2  and 6, 7, 8 o'clock positions. Probably more weight is needed in the lever pendulums - but it will not exceed 2:1.
the pendulums cannot detach from the crossbar weight.
the crossbar weight slides radially back and forth
only two crossbar weights needed for continuous motion?
AZ
Model attached
PS: I have no idea how to project this onto a wheel in Working Model. Help appreciated.
PPS: Look at the Gravitational potential energy ratios!!!
Could you make a movie of two of your working model 2d sheets and put it on youtube? Thanks in advance.
mondrasek
AZ
AZ, your sim shows the 9kg Crossbar gaining 58.726J.  The 3kg Pendulum is loosing 79.835J.  So the system looses a total of 21.109J.  That means that the Center of Gravity of the entire system is becoming lower.  IE, Energy is lost by this action, not gained/created.
