Free Energy Device - Eviva 1 KWatt QMOGEN Motor - Generator from Kiev
Started by hartiberlin, April 30, 2014, 08:32:10 PM
avalon
Quote from: semenihin-77 on May 01, 2014, 05:38:03 AM
Автор этих моторов кинул много людей на деньги, это фейк вне сомнения.
The author of these engines threw many people for money, this is fake beyond doubt.
The common sense tells me that it is a fake too, but, regardless, I'd love to learn that there is something out there for real AND readily available for anyone.
~A
rc3po
Sounds pretty good. I'm not sure how much extra current would be available when you subtract what the motor needs to turn the generator though.
I have a better design idea that incorporates an added system into the mix, but I can't afford to build it at this time. Hopefully within 6 months or so I'll have a working model to test.
havuhung
Quote from: rc3po on May 02, 2014, 07:02:18 AM
Hi rc3po,
I'm just curious bit with the idea of you just said. You can share your ideas?. .
rc3po
Quote from: havuhung on May 02, 2014, 07:10:54 AM
Hi rc3po,
I wasn't going to but, you know what, yes, I will since I'm a poor disabled guy.
I took a lot of heat from some jerks on another forum but I'll see what you guys/gals think.
Ok, it's a similar system, except between the motor and generator, we install a hydraulic system.
We know the mechanical advantage of a hydraulic system is X100: The overall efficiency formula for a Fluid Power Motor is: Overall efficiency = (Horsepower output/ Horsepower input)x 100.
So, a 1 HP motor powering a hydraulic system, should be able to turn a more powerful generator than the motor can directly as shown in the video, where he has the motor hooked directly to the generator.
You may not get 100 times more, but it should improve the power very much.
What do you guys & gals think?
havuhung
Hi rc3po,
Truly incomprehensible that the system will generate mechanical energy from the excess output versus input! Sorry you because I have not ever seen firsthand the magic! . . well so can not judge anything. . .
