Lasersaber strikes again. A joule thief king ?
Started by hoptoad, May 01, 2014, 02:54:40 AM
d3x0r
I did have a setup that had a mode that was a touch-sensor... very reliably; used a tiny inductance coil (24 turns 1" mobius) , and touching the coil on the low side of the LEDs (opposite the base) would make it turn on very brightly.  very very reproducably.  Often I end up using my body as the Megohm resistor for starting (toughing power and other points on the circuit) but this was just me touching it; and I was fairly not grounded.... thought about filming it; but I doubt it's reproducable effect
MarkE
Quote from: d3x0r on June 13, 2014, 10:20:00 AM
Sounds like capacitance.
Yes, capacitance. I've got them that do this too. Even this present circuit will do it when properly tuned.
I can't find 2sk170 locally and I keep forgetting to order them.
Meanwhile, more on burst oscillations, or rather oscillation bursts. There are at least three different oscillations happening here.
Preva
И снова ЗДРАВСТВУЙТЕ!
Сделал схему не на броневом сердечнике, а на феррите от строчного трансформатора. Вот, что получилось
http://youtu.be/iTVlVBkm_CA
Интересно, что трансформатор работает как с ферритом, так и без него.
И до сих пор не могу добиться работы схемы Lasersaber более 10 минут с конденсатором 4700 мФ
And again HELLO!
I made the scheme not on the armored core, and on ferrite from the lower case transformer. Here that turned out
It is interesting that the transformer works both with ferriy, and without it.
Also I can't still achieve work of the scheme of Lasersaber more than 10 min. with 4700 mF
a.king21
Preva:  you need to use exactly the same transistor. Other transistors won't work.
