Grid tie inverter question.
Started by tinman, May 03, 2014, 05:37:20 AM
e2matrix
Well that depends on when you got your inverter.   That law may have been mandated in some areas and at some time in the past but I've had a couple high power grid tie inverters that will run and can feed back to the grid when there is no power coming from the grid if you program them that way.   I will assume new inverters being sold in the U.S. will not be able to do that.   The ones I had in the past were not  programmed that way because I knew it would be dangerous.
