The Holographic Universe and Pi = 4 in Kinematics!
Started by gravityblock, May 06, 2014, 07:16:02 PM
0 Members and 16 Guests are viewing this topic.
ACG
Page 1 of N
Dibs on N passing 100 in 6 months time.
@gravock: I know how to achieve and maintain Voltage Rise by Standing Wave Resonance, which I think is what you are describing. By controlling reflections and turning phase angle knobs I can accumulate charge and bounce it back and forth in a waveguide or other resonant cavity, reinforcing itself almost like a laser, but with charge instead of light. And the QEG people had better hope that never happens there on their cluttered workbench with improper insulation, layout, routing and components. If they ever do actually generate 28 kV in a resonant, reinforcing tank circuit of the kind I think you mean, making use of VRSWR and tuned cavities, they will wind up in a world of hurt when their _wrong type_ capacitors explode or they create an arc that couples some tender flesh to the discharge from the caps while resonating. They will find out what the "near field" really means.
(They are actually operating, or trying to operate, in a very dangerous range of voltage and current. I'd rather work on a 500,000 volt electrostatic system than a 30 kV system connected back to the mains in any way, and I have considerable experience with both regimes. There is a reason that Dr. Frankenstein used those big knife-switches....)
gravityblock
Quote from: ACG on May 07, 2014, 02:20:40 AM
Page 1 of N
Dibs on N pages of useless comments passing 100, such as your meaningless post in 6 months time.
Gravock
gravityblock
Quote from: TinselKoala on May 07, 2014, 05:08:27 AM
I agree, we shouldn't operate in a more dangerous environment than need be.  Do you agree a load will dissipate the energy and reduce the gaps, which will reduce the charge density in the gap, while relieving the "pressure"?  We can use a dummy load to reduce it all the way down to where there is little to no charge density buildup with little to no voltage/current present if need be, in addition to controlling the knob of changing phase angles to maintain a safe operating condition.  In other words, the load + dummy load will be in resonance and can either oppose, re-enforce, or be neutral with the induced standing wave of the QEG while suppressing any runaway effects down to a desired safe level, and be in a state of perpetual vibration similar to that of an atom.  I'm sure you have more ideas on how to make this a safer build.
This isn't for your average tinkerer, amateur, or hobbyist working in their garage.  So, someone needs to step up to the plate, and you can do this!  I know you can.  You are the chosen one!  Don't let us down.  Do you accept or not accept to take up this heavy task in order for us and others to learn from, so we may further our understanding and be able to realize the goals of this forum?  Is there anyone else out there who would like to take up this challenge?
I'm squashing my previous dib on N and modifying it.  So now, let page N be large with research, experiments, documentation, videos, references, builds, etc., and without page N being filled with useless and meaningless comments (this little tidbit is not being used in reference to the posts made by TK).
Gravock
ACG
