Solved how to move water up a mountain without energy
Started by gmbajszar, May 06, 2014, 10:53:32 PM
gmbajszar
If you look at the last drawing on my page, you see how water can be moved up a hill.
http://gmbajszar.wix.com/mbcim#!mouse-wheel-perpetual-motion-machine/cgbn
The box filled with water pulls down, so that produces sucking. We use hoses, but see the picture.
I also have a few working perpetual motion machine concepts toward the bottom of the page,
but need studying the pictures to understand.
This is the first time water can be moved up a hill.
George
Marsing
Can you post your drawing here,
water move up a hill is nature phenomena.  :)
gmbajszar
Sure, the concept for water sent up a mountain is here.
Notice a second box inside a box that pulls down with water in it, which then forms a pump that pulls the water up from the neighboring boxes.
George
Marsing
i don't know,
if there is air in your original drawing, probably your system will end like this. because air is compressible and expandable.
gmbajszar
The concept would work, but one has to see that a box is made of two boxes. The lower box pulls down with water in it. Water pours in from above, and the whole system is air tight. Gravity pulls water up through them through a hose. Water comes in at the top because there is a ton of water resting below and creates tremendous pull through the hose. The pull helps water rise in the hose that comes from the bottom of the box to the right. Only water can come out from the bottom of the box. Air cannot pass to the neighboring box.
George
