COP 20.00 (2000%) Times, Reactive Power Energy Source Generator,
Started by synchro1, May 07, 2014, 01:25:54 PM
listener191
All,
After trying many schemes, the parallel charge series discharge scheme with an added shunt cap across the source transformer secondary, appears to provide the correct conditions.
The switching does not have a gap between charge and discharge  so the waveforms are not exactly the same as the Babcock Murray ppt presentation. My setup is in a different configuration at the moment, so I will have to make changes again to try this out.
Barry
$ 1 5.0E-6 17.532943091211475 50 5.0 50
r 576 208 672 208 0 200.0
w 800 288 800 240 0
r 800 288 800 320 0 0.01
c 800 320 800 384 0 8.0E-6 -20.254189688161517
r 800 448 800 480 0 0.01
c 800 480 800 560 0 8.0E-6 -20.254189688161503
178 736 288 736 368 0 1 1.0E-9 1.000000082740371E-5 0.05 1000000.0 1.0E-9 1000000.0
178 912 400 912 480 0 1 1.0E-9 1.000000082740371E-5 0.05 1000000.0 1.0E-9 1000000.0
w 800 384 912 384 0
w 848 448 800 448 0
w 848 448 848 496 0
w 912 384 912 400 0
w 864 400 864 352 0
w 880 400 880 352 0
w 880 352 944 352 0
w 864 352 864 304 0
w 944 352 944 304 0
v 864 304 944 304 0 2 100.0 5.0 5.0 0.0 0.5
w 688 288 688 256 0
w 688 256 864 256 0
w 864 256 864 304 0
w 704 288 704 272 0
w 704 272 944 272 0
w 944 272 944 304 0
w 800 448 720 448 0
w 720 448 720 368 0
w 896 480 896 560 0
w 896 560 800 560 0
T 448 432 544 352 0 4.0 1.0 -4.1811425302460865 4.630913361807858 0.999
w 544 432 544 560 0
r 448 432 384 432 0 0.01
w 384 352 448 352 0
v 384 352 384 432 0 1 50.0 230.0 0.0 0.0 0.5
w 736 288 736 208 0
w 592 560 544 560 0
w 736 208 688 208 0
w 592 560 800 560 0
w 544 240 544 352 0
w 736 208 800 208 0
w 800 208 800 240 0
c 544 352 544 432 0 5.7499999999999995E-5 40.649719064582946
w 848 496 928 496 0
w 928 496 928 480 0
w 576 208 544 208 0
w 544 208 544 240 0
w 672 208 688 208 0
o 0 64 0 291 164.0373635303281 0.8201868176516406 0 -1
o 0 64 1 291 109.8546543268058 3.0517578125E-205 1 -1
o 32 64 0 291 458.22246269559935 9.16444925391199 2 -1
o 32 64 1 291 1047.4849945267654 4.8828125000000005E-155 3 -1
listener191
All,
After experimenting with various schemes, I eventually came up with a charge push scheme that uses an additional 115V (but even better results with 230V) winding, to supply an in phase half sine push to the cap after charging. This allows the cap to discharge just after the peak of the half sine and allows an average return power equal to the average forward power through the load. The attached were taken using dual 115V windings. The attached shows 1.58W average power (differential) from source and  8.07W average in load.
Use of a 230V push winding allows larger caps to be used for example 150uF, and the best achieve with the scheme so far is about 30W averag in load for 4W average source power (differential).
Barry
listener191
All,
Attached is a shot of the load voltage/current and power measurements for the latest trasnformer setup with a 230V push winding. The discharge waveform now has almost equal area as the charge waveform. A further improvement might be to phase shift the push sine slightly, so the peak is on the charge sine falling edge. This would reduce the fall off on the discharge pulse trailing edge.
Barry
listener191
All,
The 26W load average shown in the previous post is being supported by 42.5W average on the primary. The cap charge and discharge with push is clearly seen as forward power on the primary, with no sign of any power return.
The unloaded transformer draw is about 2.5W
On the secondaries the charge/discharge power averages to 3W or so over the two half cycles.
It remains to be seen if the return power truely manifests as negative torque on a generator.
Barry
popolibero
Hi Barry,
excellent work. I'm working on the generator side of things, but am waiting for a new one to do some better testing with it.
Mario
