COP 20.00 (2000%) Times, Reactive Power Energy Source Generator,
Started by synchro1, May 07, 2014, 01:25:54 PM
hartiberlin
I think it is most important to just only switch on the caps for a short moment
during the first quadrant and not the full 90 degrees.
Also it could be good to match the TAU values of the charge and discharge, so
Tau1=Tau2 = R1xC1=R2xC2
So during charging, you half the load resistor ( 2 lamps in parallel) and during
discharge you put the 2 lamps in series..
Is nobody here, who was at the conference and wittnessed Jim“s presentation ?
Were there any block diagrams shown ?
I bought today the Dynaflux video
http://bit.ly/dynaflux
but it only has another demonstration to
the older dynaflux generator ( which by the way is also very interesting !)
and the SERPS circuit video shown is the same
as the free video posted by Aaron.
I hope Aaron will soon have the presentation video ready from the conference.
I posted these in another thread as an illustration of a particular point, but it seems that they are even more relevant here.
Below:
1. Test setup, showing zero-wire power transmission to receiver, as tested.
2. DC input power: verified as straight DC, no ripple, voltage and current values shown on DMMs were verified on oscilloscope using 1 ohm CVR
3. Output measurements: V across transmitting loop, I as Vdrop across 0.25 ohm precision non-inductive Ayrton-Perry-wound current viewing resistor in series with loop
4. Phase relationship in output V and I
hartiberlin
TK, what do your postings have to do with the Murray SERPS circuit ?
What is your circuit diagram ?
havuhung
Quote from: TinselKoala on July 13, 2014, 05:02:02 PM
Heh... it looks like folks are well on the way to inventing the solid-state inverse Marx bank.....
Hi TinselKoala,
yes, this device provides energy consumption load but kWh meter (not running) makes people look at and think that it is a device (used to deceive meters). however with a bit of analysis it's working principles to consider, there are interesting things. . .   :D
