COP 20.00 (2000%) Times, Reactive Power Energy Source Generator,
Started by synchro1, May 07, 2014, 01:25:54 PM
Quote from: hartiberlin on July 13, 2014, 08:12:10 PM
TK, what do your postings have to do with the Murray SERPS circuit ?
What is your circuit diagram ?
"MY" circuit diagram was posted, twice, or perhaps 2 1/2 times, on the previous page of this thread, by x_name41. Some of my component values are different but the circuit is the same: a ZVS Royer-Mazilli type autoresonating circuit. Just get rid of the Red Herring "bi toroid" which is a wasteful power sink, and the "primary" becomes your transmission loop (with the 3-parallel spiral heavy conductor construction, or even copper pipe) and the reactive power accumulates by resonance and circulates within the tank circuit formed by that loop and its capacitors. I don't know what a Murray SERPS circuit is supposed to be, but I've clearly shown you a working, battery powered "Reactive Power Energy Source Generator". And it uses the same schematic but different component values from what has been posted in this thread by someone else, without anyone complaining.
Not only that but my remote wireless receiver "converts VARs" into usable power that is dissipated in the light bulb.
But please, if all that is off-topic, I apologize, don't let me distract you.
SeaMonkey
Quote from: havuhung
...people look at and think that it is a device (used to deceive meters).
Most power company provided KiloWatt Hour Meters have the
ability to distinguish True Power (Real Power) from Reactive
Power and therefore are able to develop consumption numbers
for billing purposes which are accurate.
If in fact this device electronically produces Voltage and Current
relationships to simulate Reactive Power in order to confuse the
meter so as to avoid consumption based billing then it is a case of
deception.
Where does the power dissipated at the load actually come from?
Is it grid derived power or is it produced by some sort of Magic
within the device independent of the grid?
The exotic waveforms produced by the device would lead one to
suspect that it is in reality deception at work...
It would be interesting to see what sort of evaluation would be
rendered by Power Company Engineers.
MarkE
Quote from: SeaMonkey on July 14, 2014, 01:08:10 AM
deception.
Traditional residential meters, the kind with the spinning disk are very immune to power factor variations.  They read true power with very good accuracy.  The new smart meters calculate: imaginary power, VA (apparent power), and real power.  Real power is never greater than apparent power.  If the power company starts billing residences for apparent power, residential bills will go higher.  Adding phase shifting capacitors or coils that take the PF further away from 1.0 will only make bills go up.
SchubertReijiMaigo
Quote from: TinselKoala on July 14, 2014, 12:45:22 AM
Interesting a sort of near field resonant coupling but I guess it's not OU, the second coil couple and pump power from primary...
tinman
Quote from: MarkE on July 14, 2014, 01:31:34 AM
No so MarkE. They can be fooled like most meters today.
Example
http://www.youtube.com/watch?v=jcPKz7uEq-8
