Thanks to ALL for your help!!
Chris Hunter "Alaska Star" releases an O U PDF
Started by ramset, May 12, 2014, 08:01:01 AM
ramset
All
after speaking with Rob Mason I will share this here.
One very big moment working with this PDF happened under the
guidance of Rob Mason [ member Evolvingape]
He Observed that The exhaust from an ICE or better yet a diesel ICE
would be a marvelous source of Heat to increase the Delta T in this system...
to put it in his words[if I remember correctly]
The total input to the prime mover will be the fuel to the ICE ,   from that point on all energy produced in the system , {"system" Here being a combination of the "TWO"  techs, the ICE and Refrigeration engine into one symbiotic mechanical engine]
will be put to work first in the ICE stage and next as a heat source [exhaust and water jacket] for the Refrigeration part of the engine , making _THIS_ ICE drastically more efficient than anything the world has seen.[of course the fridge part of the motor will also be harvesting some energy from the local environment in a well engineered system]
so you can forget your Static "Solar" or your "Water" heat sink models [lakes and such]
we can take those static models and make them Mobile with the normally wasted  heat from an ICE engine...
Brilliant to say the least
Thank you Rob Mason....
and of course Chris Hunter for the original PDF
Chet
Thanks Grandma
