Carlos Benitez patent No.17811 circuit drawing self runner
Started by Jeg, May 13, 2014, 01:55:44 AM
conradelektro
Quote from: a.king21 on May 13, 2014, 04:52:52 PM
http://www.tuks.nl/pdf/Patents/Benitez/GB191417811A.pdf
is the patent. Note there are 2 variations indicated by the dotted line.
The dotted line version is simpler.
Thank you, I found the patent which is an old British patent from 1914.
Unfortunately there are no capacitor values and no transformer ratios disclosed in the patent.
To fire the spark gap a very high Voltage has to be fed into the system. May be it was a way to use the high Voltage from an electrostatic machine to turn a motor.
There are no good ways to step down the high Voltage from an electrostatic machine, e.g. to charge a battery.
Greetings, Conrad
Farmhand
conradelektro
I attach the patent in case someone does not find it.
Greetings, Conrad
Jeg
Thanks for the links guys! :)
Few things to mention..
1. The way for more earth currents extraction, by the use of transformers (see 70, 71). The Secondary makes quicker the capacitor charging.
2. During operation as Benitez describes, C9 collects more charges than C1 needs for, so there is a continues amplification cycle by cycle
3. The way of powering the load (10). In a conventional thinking, the primary is a shortcut but it is not. As Tesla showed clearly, there is a potential difference between both sides of the primary because radiant energy moves so quickly after each discharge that even on the same cable there is a difference between two close points. And here someone can understand that by adjusting this distance we have a potential control!
Doted lines show an extra stage if someone wants more current at the load
Resonance is important between the different stages. For example, secondary 71 combined with the capacity of the diodes has to form a resonant freq equal to that of C9 and 70.
Please express your opinions technical or not, so to gather everything it needs for a successful replication.
Tnks Jeg
