Thanks to ALL for your help!!
TPU successfull replicaction? COP=10 1kw torroid
Started by Neo-X, May 17, 2014, 02:35:52 AM
e2matrix
Inventor's web site for the patent odumy uploaded:  http://the-molina-institute.org/
Very interesting site and info.   Look at his "A Solution for to the Energy Crisis and Global Warming" pdf.
Well Bruce, I am going to assume that you don't have full edit control over all three currently showing TPU threads.  When you delete comments like that you are only showing your own weakness.
I asked you were you are in your work.  The reality is that Nature and logic and science are all against you, you are up against all of that.  Nor have you shown any positive results.  Then I stated that there is no such thing as "Earth magnetic waves."  That is the reality on the ground as we speak right now and fantasizing that they exist will not make them magically appear.  SM was a fraud and you are chasing after a phantom.
You claim that "I don't do experiments" and that's true.  However, I did lots of experiments in the past.  I made an estimate a while back that I have something like 4500 hours of bench time.
Just "doing experiments" doesn't necessarily give someone credibility either.  There are lots of GIGO experiments on YouTube.
You ultimately hurt yourself when you wield the axe of censorship.
Osiakosia
Quote from: Neo-X on May 17, 2014, 02:35:52 AM
I found this pdf document saying someone has built tpu using ferrite core. Is this true? I need more information about this.
The main experiments were maid onthis shape of ferite .
Osiakosia
Bruce_TPU
Quote from: MileHigh on December 09, 2014, 12:50:50 AM
I have banned you from my thread Mile High.  I have NOTHING to say to you, ever.  You are full of HOT air and NEVER build anything nor experiment.  You are a talking head, a PC hero.  Sorry, just how I see you.  ;)   So....  I will NOT be answering your questions now, or ever.  lol
Have a great day!
Bruce
Bruce:
Do as you wish. I am not making any claims but I have built things and I have experimented.  Right now you are the talking head.  You are like a late-night infomercial.  Nothing you do is real until the time arrives where you actually show something that works.  That is what it is all about.  It would appear that you have been at this for several years but you don't have anything to show for it.
QuoteI will NOT be answering your questions now, or ever.
Stick your head in the sand for now.  But when you come up for air,the outstanding question from everyone is "Does it work and can you do a credible demonstration proving that it works?"
Eventually you are going to answer that question Bruce.
