TPU successfull replicaction? COP=10 1kw torroid
Started by Neo-X, May 17, 2014, 02:35:52 AM
Quote from: Bruce_TPU on December 09, 2014, 06:19:18 PM
As always you make the mother of assumptions!  Ha!  But hey if you wish to continue your endless dribble for another 8 years, then hey...
And why would I tell YOU anything?  Hmm....okay I wouldn't!
Forget about playing the "bad boy" Bruce.  When you do that you are just being a pretentious poseur.  Do you have something of substance to offer after 7+ years of TPU experimentation?  What about stringing the wire back and forth in your back yard to find the "acoustic resonance," did that do anything for you?  Do you have a TPU that can output more power than you put into it?
That's what people want to know.  They are not interested in chess moves where you attempt to be witty and dismissive of everything I say.  We are not interested in amateur trash talk, we are interested in knowing what your results are.
Bruce_TPU
Quote from: MileHigh on December 09, 2014, 06:29:20 PM
YOU will never know!   ;)
Goad all that you want...lol.
What part of, "I don't want to dialogue with you" don't you understand?   Are you that dense?  Why are you and your buddies still tolerated on this forum?
Sleep well, mumbling to yourself, "it's impossible,  it's impossible",  as you placate your own mind.
I came looking for a chemist,  and found that and your hot air.  I asked for a chemist or someone with chemistry experience.   You are neither.   So instead of engaging in dialogue with someone who never wants to dialogue with you or the other one, you then are harassing a member.  And perhaps I shall have you put on read mode only for the next 6 months.
So, fo the final time, PLEASE do not have dialogue with me.  Thank you.
