TPU successfull replicaction? COP=10 1kw torroid
Started by Neo-X, May 17, 2014, 02:35:52 AM
Paul-R
Quote from: FatBird on May 17, 2014, 09:24:15 PM
I wonder where a person could buy a Core like that?
What about these?
http://www.micrometals.com/parts_index.html
Also, what about a toroid from a regular toroidal power supply transformer?
http://damencnc.com/en/components/electronic-parts/power-supplies/486
They don't say what material it is made of.
Osiakosia
Quote from: Neo-X on May 17, 2014, 02:35:52 AM
I found this pdf document saying someone has built tpu using ferrite core. Is this true? I need more information about this.
Hi Neo-X ,
The ferite , that Arūnas used was not toroidal shape ferite , but ferite from old TV tube .
So if you want to use another type of ferites the frequency rage will be different then in this document .
Osiakosia
ramset
Odumy
Thank you for sharing the patent ,any more info would be great.
Thx
Chet
Thanks Grandma
Bruce_TPU
It is ROUND like a TPU but it is NOT a TPU.  LOL
Sorry...
But I will throw you all a bone...
The REAL TPU does indeed have iron in it.
Cheers,
Bruce
