1939 Gravity Power - multiply power by 1200%
Started by cipbranea, May 21, 2014, 01:38:08 AM
rc4
Weight is only there for create forces and inertia between 2 objects, like spring but with spring the distance in rotation is limited to oscillations. I can't imagine how this system works, lack of datas. Think only in 2D first, 2 objects in free rotation with friction, friction give torque to each object, but with different moment of inertia the work from each torque is not the same.
If I'm right, each "arm" produce a torque, this torque is transfert to main system, but moment of inertia is not the same so the work too.
turbogt16v
the device is not powered by gravity,but it uses gravity to ad more power on lover axis so the device would practical take
gravity that act on weight and ad it to device forse on lower axis.
seychelles
hi guys let us cut all the bullshit let us find somebody who can but build the machine and let all just finance it.. I am a gambler and I believe it did do what it says it did..so I will start with $20...and let us not waste time lets just do it..
rc4
Quote from: seychelles on June 05, 2014, 10:27:27 AM
It's important to understand how the machine works, if not maybe you forget something and the machine don't give energy, and you think it's a bad idea. You have a brain, you can use it.
Maybe each centrifugal force give a torque to the central plate (where 3 objects are connected). The central plate turn around its center of gravity due to FC1p/FC2p, this torque is apply to the motor too but like it don't have same moment of inertia (it's logical if I'm looking at masses), the works return to the motor is not the same. The torque around the center of gravity of plate added a works for the system.
Note centrifugal forces don't add work and don't substract too. I speak about a torque, center of gravity, and moment of inertia.
turbogt16v
nice to see some constructive ideas,apart from few Einstein that argue about meaningless facts...
to seychelles ,you can construct your own device in lover measurements and with only one rood to see if it works for 20 $.but we need full working scheeme.
and to rc4 here is repost just to help http://texashistory.unt.edu/ark:/67531/metapth73611/m1/2/zoom/?zoom=5&lat=2690&lon=3903&layers=BT
