1939 Gravity Power - multiply power by 1200%
Started by cipbranea, May 21, 2014, 01:38:08 AM
Staffman
This kind of looks like an application of something that I used to do as a kid. I would take a chair and spin it using my hand... imagine holding the top corner of the back and then balancing the chair on the leg (front leg, opposite side). I used to get it spinning by letting the weight of the chair 'fall'. It used to drive my mother nuts. You can get it spinning very quickly, by moving your hand in a circle. Just let it 'fall' and it 'seems' that there is very little energy being expended to do so. Anyway, I suspect that it's basically a flywheel effect... but I've never really thought about laying out the numbers.
havuhung
Hi All,
Considering the video clip, the machine can really power efficient. 8)
Thank a lot.
quartz
   What strikes me in these images is the similarity with the movement of the planets.
we rotating masses on the non-aligned axes.
it looks like the planets and their satellites.
Chaque minute qui passe est une occasion de changer le cours de ta vie
havuhung
Quote from: quartz on May 22, 2014, 03:18:54 AM
Hi quartz,
The bottom of the machine, the left side has a horizontal axis, the outer end of its rotation by transmission belt flat on a intermediate shaft mounted near the roof of the factory. The shaft has a gear system the bottom of the machine, its mechanical connection to the pair of dumbbells and rotate the shaft to tilt you see. . .           ;)
havuhung
Hi All,
Those mechanical design and built a great machine!
