1939 Gravity Power - multiply power by 1200%
Started by cipbranea, May 21, 2014, 01:38:08 AM
gotoluc
@centraflow
Mike, thanks for looking in an elliptical mechanical solution!... doesn't look like an easy thing to do.
Also, have a look at the new attached test 3 video with universal joint. I stopped the weights for you, so you can see the lever drive continues on with no problem.
@mscoffman
Thanks for your analysis of the mechanical actions
@I_ron
That was my hope that it would work with the lower shaft off center but unfortunately it is not enough. See the test video.
Link to new video: https://www.youtube.com/watch?v=Hvy7zuWKaF4&feature=youtu.be
havuhung
Quote from: gotoluc on June 19, 2014, 02:12:50 PM
Now looking for recommendations on how I can easily convert my top gear so the lever is turned in an elliptical orbit to further test this possibility of being the right thing.
Luc
Hi gotoluc,
To create motion elliptical shape, structural mechanics have a following way: two coaxial discs rotate in the opposite direction with the arm length difference, probably easiest done.
                     Simulation video clip: http://youtu.be/Omsge0rQbe8
turbogt16v
hy luc
I don't know if you would listen to me but i will still say my opinion,
1.you need to get rid of that lace on the 2 weight ,it is lowering the output power
2.the plate is straingt not bend on the 1 weight,don't know why you did that
3.looking from the top down ,the 1 weight is at 12 o clock ,and 2 weight is at 9 o clock,input lever is at center, see video
4.you need a bearing on 1 weight not because you can freely stop top , but because then it need less input power
5.fix lever at gimbal,it will cause less pressure on weights so they will move with less friction
gotoluc
Quote from: havuhung on June 20, 2014, 01:28:22 AM
Hi gotoluc,
Good elliptical mechanism havuhung
Thanks for sharing
Luc
gotoluc
Quote from: turbogt16v on June 20, 2014, 04:42:45 AM
hy luc
Thanks for your opinions
Luc
