1939 Gravity Power - multiply power by 1200%
Started by cipbranea, May 21, 2014, 01:38:08 AM
Just..Sayin..
Quote from: centraflow on June 27, 2014, 06:48:03 PM
If you take a circular track that a steel ball can run around, then create a wobble of that track, the steel ball will continualy go around until you stop that wobble, what is causing the ball to go around?
Answer, gravity, why? because the wobble changed the relation of the center of gravity with that mass. It does not matter how much that steel ball weighs, what matters is how much force is needed to create the wobble, vola.
regards
Mike 8)
You are correct... just watched this video where the gravitational aspect of this device is explained with a small model replication....
https://www.youtube.com/watch?v=pw3lpFvuzps&feature=youtu.be
ARMCORTEX
Hmm that is also the idea I had in mind, the rolling track with the ball, this is definitely a wobble, reminiscent of godlike breakdancers, this could exlain how they get so much velocity .... (kidding)
But I could be wrong about them being all out of phase, it makes the frame shake a lot imagine 400 pounds... I think this problematic
maybe there is an ''anti-wobble'' opposite, just like many arms in unbalanced wheels. That counteracting makes a lot of sense.
But I definitly think the gimbal needs to be maximised for best rhythm, up and down was kind of glitch, it needs smooooth up and down perfect up and down.
turbogt16v
http://videobam.com/vDxPm
input 3v could work on 1.5 if made beater ,
will check output later,if less than 60% i give up
havuhung
Hi turbogt16v,
Well, you keep testing power output.
Thanks
gyulasun
Quote from: turbogt16v on June 29, 2014, 04:58:48 AM
input 3v could work on 1.5 if made better ,
You have to estimate pretty well the efficiency of your output convertion too, be it an alternator or generator, whatever.
Unless you do a Prony brake test..  So do not give up yet.
Gyula
