1939 Gravity Power - multiply power by 1200%
Started by cipbranea, May 21, 2014, 01:38:08 AM
ARMCORTEX
From the midpoint, where else  :P?
From what I see, there would be some strain on belts , speed is different for both at any time. This might be a thing for double motor double generator.
To know natural resonance of system, pull real strong on one side and add dead weights, then see natural frequency oscillation of system, then choose motor speed.
Things are gonna have to give (slip) somehow, because speed is constantly oscillating.
Whats interresting to me, is how to deconstruct the ''push''. On a perfect angle, the push is as strong as added centrifugal force of both weights, how to know
if this adds to rotation force is where I am stuck, I need somebody strong in physics and good with Mathlab to confirm workability.
Problem with these systems, as we know, loads kills the resonant causing motion.
I cant go further with Algodoo, as chain link seems to not wanna work the way I want it, somebody should try on wm2d.
Madeo
oh i see, i was having difficulty visualizing where the drive motor and generator would be located. Putting a load on a resonant system remains to be a big problem. If we can have the primary/input indirectly affect the output like the Milkovic machine, then it wouldn't be a problem.
noonespecial
Quote from: ARMCORTEX on November 21, 2014, 07:35:13 PM
https://www.youtube.com/watch?v=122I1e3y8ic&list=UUpWUFx1jGHLKoVECzc4jzEQ
Take a look at this charlie, a spring device of my own design.
There's so much going on there its hard to tell what you are trying to show. Are the 2 offset weights rotating independent of each other? If so, do they fall into some type of synchronization? And I assume the single one is a control?
Thanks,
Charlie
ARMCORTEX
The milkovic pendulum cannot turn a generator, milkovic has tried, power is only small moments and cannot be harvested by a generating or provide constant torque.
There is a pic out there, of a milkovic wheel of humongous proportions, a fix that to fix that to fix that issue, in the end, a nightmare.
Charlie: theres 2 motors, antiphase, cw and ccw. very simple...
I messed around in algodoo with sixto ramos design and ucross design, to realise that these designs are total shit and frauds, Artoj has been perpetuating a fraud.
I looked around the whole YT , to never find a loaded sixto ramos, only a bunch of abandonned builds and ''it dont work'' in russian language in the comments below.
Never trust a blind man to build an OU generator, because it wont work. He will win a prize for being an ugly SOB then ask for 75000$ US dollars.
Sixto Ramos, ucross, Skinner, do not WORK.
In mechanical realm, we are left with only a few remaining concepts,  Dimitriev (maybe), Bobby concepts(maybe) and pulse flywheels like Chas Campbell(the best), and perhaps Jim Murrays, universal engine.(maybe)
akbill
I think You have it 90 %, however I can't see why You are trying to reproduce skinner.
The basic concept is simple.  The Mann Prime mover is another example of a machine designed to hide the obvious, by using allot of extra and complicated parts.  But if You have a working tested, IE. energy in vs. OU energy out device.  I as well as many others would be delighted to see.  Your Diatribe secrets of the skinner device unveiled is funny.  Maybe You ment it that way?
