KARPEN PILE
Started by Philip Hardcastle, May 22, 2014, 10:41:32 PM
profitis
We can take this from a strictly overpotential difference point of view without causing too much of a stir mr pomodoro.I'm going to refrain from blowing the anti-2lot horn from now on and be strictly going by the textbook.
pomodoro
Guess I'll have to try Hg as well then?
profitis
You know it (-: ...try Hg/Ag amalg
profitis
@sarkeizen.gona make your dreams come true,by the textbook.
pomodoro
Ok, started to dig around to see what I've got.  So far I have a few shiny Pt electrodes,( platenized Pt electrodes I had are misplaced but if I cant find them  in a day or two I can break a specially constructed conductivity cell  to get new ones), pure silver electrode, new glassy carbon electrode, plenty of Hg, Gold ~200mg  which I precicipated from a weak cyanide solution with dithionite.  I'm hoping to make it into a plating solution, otherwise will need to buy some 24k gold and make an electrode out of it.  I've got some palladium chloride but in solution.  I've got UHP hydrogen, Ar and oxygen.
Since the gold will take a while to sort out, I'll probably start on the Pt/Ag.  He are a few questions to save me some work and prove your concept quicky  mr profitus.
Note, electrodes are flat, about 1cmx1cm , water is milliQ quality, deoxygenated. Room temp approx 25C. Ag will be pre treated as you described, Pt trated in strong Hcl,  then both will be made cathodes in a separate alkaline solution to reduce any surface oxides
1.What conc. KOH or NaOH is preferable.
2.What distance between electrodes?
3.If I use the shiny Pt, will it work and what pre-treatment is  needed.
4.Any stirring or keep static.
5.If I saturate liquid with H2 , leave just a few mL of H2 gas above surface and seal it then connect it to a galvanometer , do you expect it to provide a constant current?
6.How long would the current last?
7.Do you expect any dissolution of the silver?
8. Do you expect any silver oxide?
9.Do you expect the hydrogen to be consumed?
