KARPEN PILE
Started by Philip Hardcastle, May 22, 2014, 10:41:32 PM
profitis
Quite a few possibilities here pomodoro.you said electrolyte was darkish,means palladium particles expanded and dislodged or silver particles dislodged.electroplating must be tight-tight. It could also mean air was creeping in from a leak and discharged the cell.
profitis
You must shortcircuit these type cells for at least an hour after construction before taking an properly equilibriated measurement.
MarkE
Quote from: pomodoro on July 18, 2014, 03:54:47 AM
The graphite anomaly has been solved.  I wonder if anyone here can solve it too, it has to do with the apparatus I set up not being perfect. its actually a big problem when studying this hydrogen powered  karpen, especially because the hydrogen on the Pd/Pt will reduce anything it can over at the cathode electrode, and it means I have to run the silver again. :-[
When you went to the graphite did you start with a fresh batch of KOH?
profitis
Use the PLATINIZED foil from your conductivity cell and see what happens.this will be a stable anode manufactured by factory.
profitis
Is your graphite dewaxed??
