KARPEN PILE
Started by Philip Hardcastle, May 22, 2014, 10:41:32 PM
profitis
If murray is using paper inbetween electrodes its probably a fuel cell.cellulose undergoes hydrolysis in alkali and breaks down to sugars fuel.murray must repeat with glass fiber inbetween.
pomodoro
Quick update. Pd/Pt vs Cu. Worked well after 3 days. Decided to try a cheaper version for building a higher voltage pile. Now trying Palladized Cu vs Cu. Also now using uhp hydrogen. I'd like to be able to power a device constantly, these cells discharge ultra quickly. Any ideas on microamper motors requiring a volt or so, or a pulsed milliamp motor that keeps spinning till the next discharge some 30 seconds later?
pomodoro
Quote from: d3x0r on August 03, 2014, 03:47:51 PM
carbon-carbon battery
https://www.youtube.com/watch?v=D6D0lKPY_as
https://www.youtube.com/watch?v=rMzI9WDaAvU
Awesome, check out how he gets so excited by the discovery! He forgot to shout eureka out loud.
profitis
A galvanometer with an on-off alarm switch circuit is one way to display power continuously pomodoro.your going to have to play around with the device to figure how many seconds inbetween pulses is sufficient rest-time for stability.the electronics geniuses on this website should be also able to give ideas if we ask them about pulse motors.the diagram below is one way to make a sealed device with a oneway gas valve attatched.aluminum foil is tossed in before screwing valve onto the device and enough gas generated to purge all air and fill with slight pressure.it must be put underwater briefly when gas exits to make sure that gas escapes only through valve and not leaks.you have to play around with Al foil and caustic soda beforehand to get an idea of what volumes H2 is generated per unit foil.
