KARPEN PILE
Started by Philip Hardcastle, May 22, 2014, 10:41:32 PM
profitis
A pendulum swinging an iron ball on a long thread near a switch-electromagnet just came to mind for demo.easy to adjust for timing.
profitis
Coat that palladium onto nickel foil for best results pomodoro.you may lose quite some power if you coat on copper family.
profitis
Coat Pd onto stainless steel shaving blades,another cheap option.make sure plating solution is acidified with ammonium chloride or dilute acids(acetic)
pomodoro
Tried the Pd/pt vs Ag with tetrasodium EDTA instead, to prevent the gradual loss of power, but deterioration of Ag surface Is visible - a gray film where immersed in electrolyte.. Same deal with conc. Ammonia.  I'm surprised as I thought these would keep surface clean but leave elemental silver alone.
profitis
Nooo pomodoro.NH3 and most amine compounds viscously attack silver and take it into solution.this is why they are used to clean silver,they strip the surface clean.forms complex silver-amines which then probably reacted with cathode H2 and partially reduced to grey Ag.use only KOH or NaOH or Na2CO3 in the silver cells.use etched silver not anodized-cathodized like we was doing before.youl get silver plating direct onto your palladium anode eventualy within the gadget if you use ammonia as electrolyte
