KARPEN PILE
Started by Philip Hardcastle, May 22, 2014, 10:41:32 PM
pomodoro
Don't worry I promise to do that before I leave. Look I don't disbelieve anything, let's let a perfectly executed experiment determine the truth. So far I'm skeptical but not looking to destroy the theory.
profitis
Glad to hear it. Its fail-proof,works everytime (-:
pomodoro
This test shall be done after I finish with the hydrogen. What voltage differential do you expect to see.
profitis
Similar voltage to my pt(-)/Ni(+) air experiment.anything between 0.1-0.2v. A lot depends on your platinizing skills.if you use manufactured platinized pt foil definitely 0.1 and up.use high impendance v-meter for stable reading or large pt foils with a normal digi v-meter.you'l get around 50micro-amp/cm2 in bursts.
profitis
Have a look in this picture.here is another spontaneously reversed potential against the standard table.2Ag + CO3-- >< Ag2CO3 + 2e-.. -0.47v (standard)/MnO2 + 2H2O + 2e- >< Mn(OH)2 + 2OH-..+0.05v(standard) .this is because O2 gas kinetics faster on MnO2 catalyst as opposed to silver catalyst.this will not work under argon.
