Selfcharging cap circuit from Larskro fake or real ?
Started by hartiberlin, May 23, 2014, 10:41:17 PM
hartiberlin
Hi All,
we had the Youtube user Larskro in the past faking
a BackEMF motor device, but he came clear and told us,
where he had hidden the batteries.
Now he has a new circuit here:
https://www.youtube.com/watch?v=Ln3YVVZbpNo
which is charging the cap in loop mode, so he is showing
overunity.
The circuit seems to be very easy.
He just has a Reed Switch parallel to a Shottky diode
and from pulsing the Reed Switch with his motor the motor
coils generate BackEMF that recharges the caps and also rise
the voltage on the cap while the motor is running.
If this is no fake with another hidden battery or wireless power
setup this definately looks like a winner circuit and a real overunity
circuit, charging the caps while running and still rising the voltage..
So this circuit seems to produce energy while running.
Hopefully he will soon show more videos of it and show it all in detail.
Regards, Stefan.
hartiberlin
Seems it depends on the cooling of the SMD cap with its nonlinear dielectric and converting heat to electric energy...
http://youtu.be/DpvLwll79Ho
Groundloop
I get the attached circuit drawing by looking at the video.
The small motor coil is connected in series with the reed relay.
He need to use bias magnets to get the reed relay to be normally
closed to get this motor running. In the Loop Off mode there is
a path from the start battery that will charge both capacitors
via the diode. In Loop On mode the motor input is from the two
capacitors.
GL.
MenofFather
Quote from: hartiberlin on May 23, 2014, 10:41:17 PM
Hi All,
overunity.
Regards, Stefan.
That simple divices usualy is fake.
