heat your house with 4 motors
Started by ARMCORTEX, May 24, 2014, 11:47:51 PM
ARMCORTEX
Use 4 motors to heat your house, but how to wire it ? How to drive sun gear and wire it ? This you will never figure out .
4 motors alone could make a decent amount of power. Like this you make huge power.
telecom
Can you please explain how it works???
ARMCORTEX
The lines indicate symmetry, I only draw a quarte of the machine
It is not my best. I had an even better idea
There is a sun gear driving arrangement and special wiring. Depending on how big the flywheel vs the motor there is no driving arrangement.
ARMCORTEX
A brushless motor would make great prime movers, disk type.
In the Y axis, you can see that a ''reflector'' could be positionned if centrifugal force is not enough to ''brake inwards'' in the lower rpms.
Bessler would be proud of this one.
The profane and uninitiated cannot comprehend, unfortunately.
ARMCORTEX
You cannot see as I do, the ellipse inside the circle, the circle feeding the ellipse, the ellipse feeding the circle.
