Starting gravity wheel project, GRAM
Started by burnit0017, June 02, 2014, 09:57:15 AM
burnit0017
Hi, thanks for the info.  I will try your suggestions. I will  post results if I find any improvements.
Low-Q
Have in mind that any lock-ups, and other movenents in the pendulums will require some sort of torque, counter torque, lost and gained energy to orientate.
Isolate every weight movements in this wheel, and analyze them separately. Do you see any reason why these movements separately, or the gravity wheel as a whole, should gain energy for each revolution by itself then?
The basic and fundamental workings of a "gravity wheel" is that all the weights that is put into the wheel, no matter how they orient themself during one revolution, are limited within a given and "fixed" change in altitude from ground.
As we all know, a given weight at a given altitude carries potential energy which is a product of those two.
As the weights in a "gravity wheel" never change their most and least potential energy, there cannot be possible to harvest excess energy - since the excess energy is zero.
Vidar
Low-Q
Quote from: webby1 on November 02, 2014, 08:39:28 AM
It is not about making excess energy,, it is all about using the energy as it is constantly cycled within the system,, you pump it up and that it is your input, Then the system is moving it around and that has work involved and that is what you get to get in the middle of.
Ok, I see, but wouldn't it be easier to use one simple flywheel with lossless bearings?
Low-Q
Not maybe. You do never get equal or more energy out than you put in. If you in addition put lots of moving parts on that wheel, it will just stop sooner due to more friction.
Vidar
Lossless bearings aren't good enough. You need _negative friction_ bearings.
Around here, we call them "motors".
