Unbalanced Lever
Started by veproject1, June 05, 2014, 06:52:43 PM
iacob alex
.....as a comprehensive , minimal but "generous" image-idea can be diversified into a variety of shapes.
     One possible test , with :  www.geocities.ws/iacob_alex/Some_Drafts/untitled026.jpg
     We intend to maintain the torque difference ( gravity unbalance ) on the same side of the fulcrum , and so , a possible continuous rotation of this simple double leverage.
      The red mass plays a constant arm.
      The green mass plays a variable arm , if paired with the blue mass.
             Al_ex
Low-Q
Quote from: veproject1 on June 05, 2014, 06:52:43 PM
Unbalanced Lever is able to run perpetually if...
https://www.youtube.com/watch?v=c9YLkoJz7rM
It's no "IF". It does not run by itself.
If you isolate the pendulum, the only thing that makes the "rotor" unbalanced, would you imagine that this pendulum will repeat cycles just by itself? I guess you'll say "No".
Again, as I have told others repeatedly: A mass that is limited to travel within a given altitude does not gain potential or kinetic energy.
In other words; There are no powersource in gravity.
Vidar
iacob alex
.....clearly evident , open to view , needs no more than two masses : if one plays a constant arm , the other must play a variable arm.
Because the movie shows three masses ( pendulum/eccentered mass + balanced lever/two equal arms,two equal masses ) , there is no hope to play a continuous unbalance ...
A seesaw is a gravity game with two partners/ masses ,only...
Exceeding what is necessary or natural is truth that lost its temper,if not the failure to find it.
      Al_ex
iacob alex
Quote from: iacob alex on December 04, 2014, 05:04:05 AM
A rotating unbalanced lever, with a single variable arm , at :
      www.geocities.ws/iacob_alex/Some_Drafts/text028.JPG
Here, the VAP (variable arm procedure ) is your choice...
In my opinion, this time we have a "redundant key/design"/movie for a gravity powered device: if we "cut" a mass , have we a lab-demo , or an "incredible toy" ?!
      Al_ex
