Thanks to ALL for your help!!
A fast device which uses inverted pendulums
Started by AB Hammer, June 08, 2014, 05:58:29 PM
havuhung
Quote from: AB Hammer on June 13, 2014, 11:50:07 AM
I am surprised that very few questions have been asked. This device/wheel may very well self rotate when the correct additions are added. I have some construction to do for the next video but it will be soon.
Alan
Hi AB Hammer,
In your device, one should add more accessories to make it work dumbbell disc is mounted on a flat steel bar and hang it high into the available holes were drilled in the cross bar, it will do work as a pendulum clock! . . But I'm not sure it helps your device run for a long time!     :D
AB Hammer
Greetings webby1
The thing in the blue box like welder stand is a 3/4 HP buffing motor (you are looking at the end of it), and the thing with the spring is part of a metal cutting band saw (but it has a box of segmented chest plate parts on it).  The steering wheel on my English wheel/roller is for adjustments of preasure.
Your next clue is. You will see it in plain view most of the video but it does come and go from view.
Alan
Alan
AB Hammer
webby1
Since no one else is guessing I will tell you where it is.
It is at the back roller of the chair. Here is a close up of the device. (PS it is not worth duplicating) but you will see some accelerating feet on each arm. Improved a little but no banana. I do tend to make a lot of stuff out of steel.
Now back to the device of the string.
Alan
Alan
AB Hammer
A message from the Terrible Twos
My granddaughter has a special gift for mimicking in a selective way.  I wonder what she was thinking?
http://youtu.be/vG1FhvOHPuA
Alan
AB Hammer
@ All
I turned the device on its side to work as a pendulum and made a video of it. I didn't talk in but I did put captions. It has a few effects to work from for some future projects IMHO.
http://youtu.be/N1ztIu10cEk
Alan
Alan
