Cascade leverage...
Started by iacob alex, June 23, 2014, 05:54:47 AM
MarkE
How do you think a pump relates to the unworkable idea of a lever that is supposed to operate itself?
           The workable idea of a lever/lifter/siphon/ram pump principle :
http://en.wikipedia.org/wiki/Siphon
Siphons are generally governed by Bernoulli's principle . This is simply a restatement of conservation of energy principle in that the sum of all energy at any given point in the siphon flow is constant. Because the reservoir generally has a constant energy per unit volume (the sum of pressure energy and gravitational potential energy is constant), the outlet must also have the same energy. The outlet has lower gravitational potential energy due to the height difference and increased kinetic energy (or dynamic pressure).[/font]
Heber
Principle of lift
A siphon or siphon is a device or a device with which you can decant a liquid from a container on the container rim into a lower reservoir or drain into the open without tipping the container and without benefit of a hole or an outlet below the liquid level has. In this case, the hydrostatic pressure is utilized. To fill the hose and set the flow process in motion, the liquid is mostly sucked by mouth.
Principle [Edit]
lifter
The two containers must be connected with a hose or the like. The piece, in which the tube is guided up and down by the same amount again, adds to the pressure differences seen in the global tube not included. In this piece, the gravitational forces of the liquid same mutually exclusive. The additional liquid in the range between upper and lower containers causes a pressure difference, so that the liquid flows due to the negative pressure resulting from the upper to the lower container, thereby overcoming the container rim.
This pressure difference depends only on the length of the excess water column from apart from the difference in pressure of the surrounding air and the decrease of gravity:
\ Delta p = p_2 - p_1 = \ rho g (H_2-h_1)
\ Delta p = pressure difference
h_1: height of the upper liquid surface
H_2: height of the lower end of the siphon
\ rho: density of the fluid (1000 kg/m3 for water)
g: acceleration of gravity
Examples [Edit]
Hydrostatic lifter
Called siphon with suction tube, also poison lifter
Cup of Tantalus (Heron-cup) according to the principle of the siphon (Communicating Vessels)
The siphon principle can be applied from a Gärballon among others when pulling off the wine.
It is also applied on a larger scale at the spillway of dams. The easily accessible example of a spillway, which is designed as a siphon weir, you can visit the outlet structure of flood retention basins Treysa goat grove.
The siphon principle in the cup of Tantalus, also Heron cups or Pythagorean cup is also called realized. If you fill it too high, it empties out to the end.
A (self-made) jack can be used for flooding as a pump for the Liberation of flooded cellars and areas of mud-water (gravitational pump): For this, a hose is left down in the flooded area, while filled with water, sealed the ends and a end to a deeper place outside the flooded area drawn (sewer or a river).
Alternatively, tubes are used which have at the top of the structure via an inlet opening. By those the tube construction is filled with mud water or tap water and then sealed at the top.
If you open then inlet and outlet, the flooded area drained. This is the faster, the greater the difference in height between the water surface and the outlet and the larger the hose or pipe radius: Flow rate in m³ / h = 50,000 x (height difference in mx radius in m) ².
So, for example, promotes a drainage tube with a diameter of 10 cm with a height difference of 1 meter approximately 125 cubic meters of water per hour. However, in a smaller tube (about 1-5 mm) is not reached the calculated performance of the hose because of resistance. In an even smaller tube (<1 mm) does not work anymore due to the principle of capillary action.
If no hose with lockable openings is present (usually), the beginning of the tube is kept under water and a second filled with tap water (openings blunt voreinanderdrücken).
In a simple system, a 90 ° curved pipe, for example, suspended with 10 cm diameter in a water container, while the longer projecting outwardly. Then, a sponge or a ball on a string quickly through the tube to the outlet of the Sly out and pulled the siphon action starts.
Heber also be used instead of pumping stations in sewer construction. [1] [2]
External links [edit]
High jumping ↑ Hamburg lifter.
High jumping ↑ The siphon principle.
Categories: Pump mode of action, tube apparatus (process engineering) liquid pump
http://www.rexresearch.com/Kutienkov/kutienkov.htm
The invention relates to pressure water equipment and can be applied for water lifting without using any additional mechanical, chemical or other energy including for land reclamation for agricultural purposes, water supply of individual cottages, under construction facilities, resort areas and other water consumers being remote from centralized power grids or not provided with fuel resources and thus have no chances to use standard water pressure equipment. It is known water-lifting device called as water hammer or a "Ram pump" for using the energy of falling water from water source being higher the ground level and providing transferring part of incoming water to a level much higher the water source thus creating a water hammer effect resulting thereby. But until now there is one disadvantage to be eliminated in said water-lifting devices - useless drain of considerable amount of the incoming water in the device via an impact valve which communicates with the environment medium, 10-15 times exceeding the volume of incoming water to a consumer. Besides, similar water-lifting devices can not be operated being fully submerged into water. The proposed invention has no such disadvantages. It is reached using an impact valve located directly inside the feed pipe and has no communication with the environment medium. The valve separates the pipe into accelerating and pressure portions in a definite ratio.
from www.borderlands.de
The professional geologist Djérassem le Bemadjiel from Chad, who has an invention for
Oil production has registered in the U.S., excited at the Exhibition of Inventions of Geneva, 2011 (p. 15f) with
its newly developed autonomous pump considerable stir. With the patent from him
claimed invention, it is possible a water without additional Fremdenergie aus
To pump deep reservoir into the air then un through the use of potential energy to electricity
produce. It is a tricky series circuit of hydraulic and pneumatic
Pressure cylinders, wherein in the 29seitigen patent also all the calculations required
are included.
http://www.kumatoo.com/djerassem_le_bemadjiel.html
           Think about the first " Manhattan Skyscraper" sanitation water delivery system !
                                         Italo-american invention
Sincerely
              OCWL
http://true-random.com/homepage/projects/diffusion_machine/
                  A small unbalance can develop a "butter-fly " effect
If in Angola,by flirring wheater conditioning( fata morgana),a butterfly moves his wings asymmetrical to the ambiental frequencies,this interferences -evolute an incoherence which over the "go west" wind/water jet stream build up a (super-)hurrican condition  in the carribian gulf zone !
So little ,but such damaging power potential ! Ketten/chain -reaktion !
                           Visible strong influence :
http://1.bp.blogspot.com/-INTQEGwzTJg/URV31ZDOQfI/AAAAAAAAHPQ/k7d4M_HeiDs/s640/Windr%C3%A4der-auf-Meer.jpeg
                                Who demands the wheater kitchen ?
Wind farms change climate indicators
My Weather
) wind farms have an impact on the climate, as research has now proven. (Photo: www.paphotos.com)
Wind farms climate change
04.05.2012 06:16
The development of alternative forms of energy as well as the energy from the wind turbine is driven in particular in Germany. The extent to which large wind farms alter the climate, has now been first investigated scientifically.
display
It could only previously be assumed that large-scale areas with wind turbines affect the climate. A research project at the State University of New York with scientists around the project Liming Zhou, have now able to prove that this assumption obviously corresponds to the fact.
Thus, the researchers found that the temperature on the surface of the wind farms in the last ten years has increased more on average by 0.72 degrees than in unused areas, such as in the scientific journal Nature Climate Change (doi: 10.1038/nclimate1505) on 29 April. was published.
In their study, the researchers chose an area in western Texas, since there several large-scale wind farms have sprung up in recent years. Then they examined using satellites, the temperature of the land surface three years before construction of the wind farm and three years after completion of the construction between the years 2009 and 2011. Moreover, even the temperatures were compared on the face of the wind power plants with those of other open spaces that have similar have agricultural characteristics.
Warmer by wind farms
After adjusting the data by filtering the general warming and temperature fluctuations between years, the temperature difference could be possible to verify both compared before and after construction, as well as developed and undeveloped areas. The temperatures of the wind farms were always higher, is also in the immediate lee of the wind turbines have a warming effect detectable. The biggest differences came into being here at night.
This can be explained as follows: Due to the rotation of the wheels, the air is better mixed. A better mixing hinders the ability of the nocturnal cooling by radiation. We know this effect already: in windy nights it is not as cold as at low wind conditions under a clear sky at the same air mass. Then the lower layers of air in the atmospheric boundary layer as mentioned can be well cooled. Located directly on the Earth's surface, it is then the coldest and the temperature is already rising sharply in the lower centimeters to.
Lost of humidity ? Desert-technology
NathanCoppedge
Quote from: iacob alex on July 28, 2014, 12:49:36 PM
.....as a closed loop ( self-repeating leverage ) process , at :
www.nathancoppedge.com/Perpetual_Motion_Summary_Prospect_RepeatingLeverage
If imagination rules the world , sometimes we can discover common points regarding a possible gravity powered device/motor/engine...or as you like to call it.
    Al_ex
For those with greater interest in my designs, there is a recent experiment based on the trough-leverage type design, which I believe to be successful. It involves motion from rest (by my definition), and although it does not yet complete a full cycle (that would require multiple such apparatuses), I believe it serves as evidence of real over-unity, which is theoretically a red-letter-day in the field of hobby mechanics.
Here are some links regarding the repeat leverage / evidence against the classical model:
VIDEO: http://www.academicroom.com/video/evidence-against-classical-model
Diagrams Page: http://www.nathancoppedge.com/Perpetual_Motion_RepeatingLeverage_Diagrams.html
Thanks to my visitors. I thrive on repeat traffic.
iacob alex
.....or a serial arrangement of two consecutive cascades :
http://imperioli.deviantart.com/art/Perpetuum-mobile-306266535
..."assembled" as a long period (variable/oscillatory...) pendulum (nearly balanced) :
www.phy.mtu.edu/~suits/PH3110/physpen1.gif
...with a single mass (M1 or M2...) moving/"sliding" to and fro (playing variable /oscillatory length ) along the arm , every half-turn , so to keep running a continuous unbalance , on the same side of the fulcrum / pivot.
    Al_ex
