Akula 1 KWatt Free Energy Generator
Started by hartiberlin, June 27, 2014, 05:59:39 PM
MenofFather
QuoteCan you advise us how do you obtain the resonance frequency of kacher and you go by tuning a kacher.
Kacher holds automatic resonance. But maybe little you can change resonance, by moving primary coil up or down or if kacher in horisontal position, then to one side or other and maybe puting primary coil not simetrical to secondary... Bysicly you can not much change frenquency of kacher. To change it frenquency, I advice made many secondary coils with diferen number of turns. Let say, one coil have 200 turns, other 300, thryd 400, forth 500, six 600 and chek with that coil is best effect. But how I write in prievous post coil secondary must not be long.  :)
QuoteThis is wild guess at this moment assume 1500khz kacher freq. 1500/4 =375khz .
Let say secondary LC resonance is 1500 kiloherc. Let say 1/4 wavelengh, who speed is light speed resonance is 1200 kiloherc. So then maybe you atach 6 turns coil who is on top other coil of akula 2 divice, then maybe LC resonance gose down to 1/4 wave resonance and be 1200 kiloherc also and then maybe you get best effect. But maybe Kacher resonance must be same like pick up coil or one of it layers resonance. :)
MenofFather
Quote from: NickZ on July 02, 2014, 12:23:01 PM
... Maybe someone can make an English translation to the schematic...
wattsup
More then a single conductor ground cable. As it enters the connection box it is hot glued to the base and you can see more then one wire.
I don't know why the guys that made the video did not take better close ups of the device. What a waste.
Also, that Tesla Coil (TC) should have shocked that guy being so close. There are two possibilities, if the TC is used to transmit energy to
the other coil, then that guy should have been shocked, otherwise the TC is eye candy and I would also presume the other coil is eye candy as well.
I am also having trouble figuring out the logic of having a battery to start the system, but you then use a start/stop switch. That logic is
counter-logic or a prerequisite if you want to fake your device. Such a switch is used when you actually have live power already waiting on
the other side. To prove this is real, that battery should start the system without a switch, then he should remove the battery and see if it keeps
running, then to shut it off, a simple momentary N/C switch is all that is required to open the line and stop the system. Anything more then that
and you can almost be sure there is live power somewhere waiting to be added to the system once the battery start
illusion is accomplished.
I think the greatest inconsistency of the Akula device is the fact that Akula makes no special discussions on the principle of how and why
he wound his coils as they are. Usually, an inventor will come up with a theoretical concept of coil coupling, then produce the coil system and
test it to see if the results match the concept. I do this every day and am sure many other benchers do it as well. But here, all we see is the
coils and there is never discussion about the base concept of the coiling systems. So what this tells me is either the inventor himself has
no clue about the coupling concept, or, most probably because there is no concept because the coiling system is just eye candy.
The point is, the more complicated your coiling system, the more time would have been required in R&D to arrive at that level of complexity because
each coil addition would then create so many more variables that would have to be tested in order to PERFECT the system to operational levels.
So when I see such TK style coiling systems, I ask myself, where did this guy find all the years required to arrive at this complex system? I would
say one guy alone would require a good 10 years of trial and error. So where are the 10 years? Akula has made more systems with varying coil
systems in one year then anyone could do in a lifetime, all alone, all functional and all chock full of discrepancies.
So for me, I think all this fanfare is confirming more and more that all Akula really is interested in is showing things that will steer the public away
from his first yoke device that we have read is licensed to a commercial concern. I have been in business for many decades and could confirm that
any commercial concern knowing he made some public videos of the yoke device, would not appreciate it at all (deal breaker) and that those public
videos may have pushed the licensee to accept the license but conditional that Akula create some distractions so the public can quickly forget
the yoke device, which for me, had more merit in design then all his other jokeronies.
Anyways, looks like we are back to the bench with our own works as this is the only guarantee we will ever have of open sourcing OU.
wattsup
NickZ
  Wattsup:
   In the some of the Akula videos, as well as his comments, you will find that he does explain at least partially why he has built his circuits as he has. Although after showing his first video device, he didn't want to tell all there is to know about how it works, just shows it working, and some basic explanations. But, many still don't believe or understand how these things work.
  In Akulas videos previous to his first device, he explains his test with the induction circuit system, (heating the wrench), from which some of his later devices were derived from.
He also explains that his smaller yoke did not work, and had to use the bigger yokes.
So, not all Tv yokes work the same.
  In the first video device, that device was shown running with NO battery, and NO ground connection.  Also, keep in mind that his second device was confirmed by Tiger to be working as shown, no fake input source, from the ground wire, or anywhere else.  Tiger is no idiot, and has many years experience in this type of devices. I will trust Wesley's word on Tiger, as he knows him well.
   Akula who is only about 30 years old, is either a genius, or has had some very qualified and experienced help. And, so has Tariel, especially with the hefty 100kw device. Which I'm sure he did not build, by himself. So, who are the real inventors, that don't want to be known? And who knows what other devices they may have invented, that we have no clue about. As by now even the Black Governments have machines that can do much more than these table top models can. Even the NASA is a front, for the real secret machines being developed in underground bases, and elsewhere. Even saying that they have not been back to the moon in over 40 years.  Possible lies to hide what is really going on behind our backs.
  Anyways,
  I have been studying the Akula second device, (as much as I can actually see of it), as well as the schematic. I'm still very intrigued by it, as ever. As the winding counts don't match the diagram, as well as some other things. The Main air coil is not wound like we have been thinking, either, like 48 48, 24 24, 12 12, (all using a single wire). etz... assuming that the diagram of it is even correct. We don't know the actual turns on any of the coils, wire gauge, former dimensions. Other than the thick outer induction primary coils, that can easily be seen. Nor any other possibly important secret details inside the two white junction boxes.
No voltage/current test points on the diagram, etz...  So, and accurate replication is going to be a struggle, at best.
Hats off to Ruslan... who never had anything to do with Akula,  if true.
  Wattsup,  good to see you here.
                                                   NickZ
Marsing
I am still waiting some news from this thread before considered as a dead thread about Roman ( Akula ) visiting Germany and hopefully meet Stefan who will do some tests to his device and show the result to us.
