Tommey Reed's Simple Vapor Carburetor
Started by TommeyLReed, June 27, 2014, 08:55:25 PM
Rigel4
Tommey,
I have or often buy a bunch of tools with ICE engines.  This carb sounds like something you can use when you look at an old car or rototiller/weedwacker with a carb that has been gunked up for 25 years. Would this work as a replacement carb for a while? Do you think it can be modified to run a car 4-6-8 cyl? I would love to know if what I am buying problems are  before I take it home. Seems very simple, I just need to make it mobile. I assume it needs a tight vacuum. Again thanks.
TommeyLReed
Hi Rigel4,
Yes this works even for the big engines, I ran my 4cylinder off a 1L jar with 1/2 ball valves and tubes.
You will have to use some of the exhaust heat to keep is from freezing up, it will get super cold due to vacuum.
Tom..
noonespecial
You don't see any need for a check valve in the event of back-fire?
Liberty
Quote from: TommeyLReed on June 29, 2014, 08:44:36 PM
Hi Rigel4,
Tom..
I ran a pontiac sunbird off of a cookie jar similar to your setup.  The fuel in the jar gets cold and separates the "light parts of the fuel, which are burned, from the heavier parts, which are left in the jar.  If one continues to run the engine, the fuel in the jar becomes only heavy parts and will not run the engine. (even if warmed up again, because the light, volatile parts of the fuel have burned). Gas vaporizes between 70 degrees or lower, and the heavy parts vaporize at up to 400 degrees.  Can be dangerous to heat gas to that temp., so be very careful.  I found it interesting, but not practical to use because of the separation issue of the fuel and heat requirements.
Liberty
Liberty
TommeyLReed
Hi Liberty,
I agree that adding too much heat would not be good.
I will show in the next few days how I use the heat to crack cooking oil into a vapor to run a gasoline engine.
Thanks for the input.
Tom.
