FREE ENERGY is here to stay
Started by that_prophet, July 08, 2014, 12:33:51 AM
that_prophet
Quote from: webby1 on September 17, 2016, 10:48:12 AM
Give it up,,
I outlined a means for this to be tested on an almost ZERO budget and what do we get in return,,, another onslaught.
Shaky hands and all,, follow my little walk through and this could be built for next to nothing but some time.  It could be built in a small corner of a small room,,,,
Oh-well,,,,,,
PLEASE, SHOW ME WHERE THIS OUTLINE IS
(meanwhile,,, back to the onslaught, lol)
Lenz law sounds like something electronic, when this works om simple pulley mechanics = 100cm circumference pulley only turns once
+ this gives you 100 turns, X,(times) the # of 1cm circumference pulleys that you attach.
If you attach AC generators to each of these 1cm mini-pulleys,
you would gain 100 units of AC electricity, for every 1cm pulley that you attach.
This could be massive amounts of free AC electricity,
if you added 10's of these mini-pulleys then you would gain 1000's of units of AC electricity,
all done with one spark of DC current, (practically zero)
that_prophet - Re: use pulleys to multiply total # of rotations = AC electricity
Quote from: citfta on October 14, 2016, 01:05:13 PM
I don't understand how you can be so dense.  You have had numerous people tell you that your idea will not work.  That is because we actually have experience working with motors and generators.
REPLY BY ME
I don't understand how mankind be so dense, to not see that this use of pulleys does not involve torque, but simple multiplication of rotations = multiplication of AC electricity. The AC generators are just winding up massive voltage, to turn over your DC motor, only the once, + no current, as you only need one spark to have this self powering.
Now try and tell me that you would not be able to get one spark of DC output,
when you have 1000's of units of AC electricity to work with
citfta
that_prophet
Re: GEM=(Geometrical Electricity Multiplication)
« Reply #61 on: Today at 01:09:57 PM »
by that_prophet@yahoo.ca
= joe Lynch
Just one of His Creations
Using pulley mechanics to multiply AC electricity
I was hoping that I could enrage many deceived people,
--- once they saw just how super simple this idea is, that these evil spirits are desperately hiding
--- --- but I have not yet been able to break this solid hold that they have on the masses
--- --- --- until now,,,
How can you not be multiplying AC electricity, when you pay for only one rotation of a DC motor,
--- with a 100 cm circumference pulley attached. (costing higher Voltage + 1 spark of current)
--- --- to crank it over once, gaining 100 cm of moving belt
--- --- --- and then getting back 1000's of units/cycles of AC electricity
--- --- --- --- by running your 100 cm of moving belt past 10 mini-pulleys of 1 cm circumference
--- --- --- --- --- thereby multiplying your rotations to 10X100=1000
--- --- --- --- --- --- ( HOW CAN YOU GO WRONG )
(WHAT I CAN'T BELIEVE, IS HOW GREAT A HOLD THAT EVIL FORCES HAVE ON MAN)
--- to hide this super simple method of multiplying our AC electricity
--- --- from His ministers even
--- --- --- as I have tried to get 3 or more churches to patent this,,,
--- --- --- --- WITH NO TAKERS,,,
(CRAZY,,, considering that once this is discovered to be real, every government in this world)
(will pass laws, mandating that this tech is used + not oil burning engines,,, which funds terrorist)
1 rotation of a 100 cm circumference pulley will give you 100 rotations for as many of the # of
1 cm circumference pulleys attached + with adding simple generators to these 1 cm mini-pulleys,
you can be multiplying your # of AC cycles/units of electricity
---  All through what seemingly legally breaks the laws of thermodynamics
--- ---  by using simple pulley mechanics, that we learn in grade school
--- --- --- to actually multiply our AC electricity - (instead of paying for oil to generate it)
YES, through pulley mechanics, you can trade one revolution of a 100 cm circumference pulley,
--- into 100 rotations of a 1 cm circumference pulley, (for every 1 cm mini-pulley you add to belt)
--- --- so if added 10 mini-pulleys, you would get a return of 10X100=1000 cycles of AC electricity
THAT'S ONE ROTATION OF A DC MOTOR BEING MULTIPLIED
--- INTO 100 ROTATIONS OF AN AC GENERATOR
It's as simple as using the laws of pulley mechanics to multiply our AC electricity, by paying for one rotation of a 100 cm circumference pulley, and gaining a return of 100 units/cycles of AC electricity.
WHY CAN YOU NOT SEE THE BASIC SIMPLICITY OF,
THIS USE OF PULLEYS TO MULTIPLY AC ELECTRICITY.
This is a way of seemingly legally breaking the laws of thermodynamics
By using simple pulley mechanics to multiply your rotations = AC electricity
remember, I have already had one man build 3 different models,,,
but he is worried about the rumors of people disappearing,
I mean those who had actually built working models
the Book that I put all of my faith in is the Word of God
+ if you want to see how the Holy Bible can prove itself God inspired
you should read a novel  called "Armageddon" by a Canadian author named Grant Jeffrey
which proved to me that the KJV Holly Bible was truly Written by God
He did this by systematically going through fulfilled Bible Prophecies,
and showed how they were fulfilled right down to the exact day
+ Who else but God, could consistently predict the future
it was one of the rules with God, the one about how He gave a second chance to Israel
after 10 times the original duration
As in, when you take 10 times the original duration, of the prophecy about when Jesus would enter Jerusalem, you get a second chance for Israel. I don't know about you, but I happen to be quite the skeptic, and thought that maybe the reasons that these prophecies worked out so perfect, was that they were written or changed after they were fulfilled. But this one about Jesus entering Jerusalem on the exact day, + when you take 10 times the original duration, of the time between when it was prophesized + when it was fulfilled, you get may 14th 1948, when the nation of Israel was reborn. http://www.grantjeffrey.com/pdf/JeffBIBLE-EzekVision2.pdf
<<< EVil-sOLUTION >>> (isn't it amazing what is revealed by the il-s of life)
http://decimationofthisevolutionfairytale.yolasite.com/
THIS IS GOD'S GIFT TO THE SOON COMING TRIBULATION SAINTS
http://free-energy.yolasite.com/
Because the Door will close on this Prophecy being fulfilled on Jan 15th , 2019
http://doorschristmustpassthrough.yolasite.com/, http://2020-vision.yolasite.com/
These are the rules God has set before us
http://beliefstoliveby.yolasite.com/
possible timing for TRIBULATION SAINTS
http://possibletimingfortribulation.yolasite.com/
UFOs + GHOSTS do exist, there are just not who they pretend to be
http://aliensandghosts.yolasite.com/
It was how God predicted, to the exact day,,, May 14th, 1948
the day that Israel would get their second chance + become a nation again
Written in the Holy Bible way back in Ezekiel's day
This convinced me that the Holy Bible spoke Truth
About Jesus Christ paying for our Salvation
+ Jesus being the only Door for us to enter Heaven
Becoming a part of God's Family
sm0ky2
The flying machine that the god(s) flew in in the Bible
Have nothing to do with generators
Or pulleys
I can build you one of those if you want one
But it will look nothing like a pulley system
With a bunch of alternators hooked to it.
The device you talk about does not "do" anything.
The alternators do not put out enough electricity to
Keep up with the D.C. Current from the motor driving them.
The motor stops and no electricity is generated.
If you use a battery to keep the motor running it will run longer
But it still stops quickly because the alternators cannot keep up.
Maybe one day technology will lead us to more efficiently motors
and alternators, and we can try this again. But as it stands with
today's technology your system fails to operate.
sm0ky2
D.C. Motors MUST have current to turn!!!!!
Even one rotation!!
The AC motors create current when you TURN them.
This makes them harder to turn
Which requires MORE current to go through the DC motor
Each extra pulley you attach adds MORE current needed
To turn even ONE rotation!!!
Without enough current the DC motor does NOT turn
The a/c current generated cannot keep up with the
DC current used in the generation.
Add more a/c generators, increase D.C. Current
Add more generators, increase current
This keeps going like that until you reach the limit
Of your D.C. Motor.
At which point it will max its' current via the resistance
Through the coil.
If you are lucky enough not to burn it up before that point.
This has been thoroughly tested and has failed to produce
Anything at all. Many different motors and generators were tested.
Many different pulley sizes and ratios were tested
Even to include the use of flywheels to store rotational momentum.
The tests failed to produce more energy than consumed by the DC motor.
