Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
0 Members and 23 Guests are viewing this topic.
TheoriaApophasis
Quote from: tinman on August 04, 2014, 09:40:00 AM
https://www.youtube.com/watch?v=9CJ8TPjL9t8&feature=youtu.be
he has one set of mags set FLAT and the other set at extremely close to the gyromagnetic precessional angle of reciprocation
same principle WITHOUT the lens here, at which, in free air, it is spinning on ONE axis at the precessional angle of 21.246 DEGREES
********The reason WHY they are (seemingly) moving opposite to each other, is you are only looking at ONE end of BOTH at the same time NOW move your hands INTERLACING ....looking DOWN on both, one will appear to be moving CW and other CCW...
....BUT, if you look at THE SIDE that is moving, you will notice BOTH hands moving in the SAME DIRECTION   CW and CW .......or CCW and CCW
In moving the FLAT SET  ONE WAY (not the fields, but the actual PHYSICAL MAGNET), and getting ONE PHYSICAL SPIN out of the convex side.........then moving them (NOT THEIR FIELDS) opposite, and getting OPPOSITE PHYSICAL movement (not their fields) changes nothing but the physical movements, NOT the fields movements.
The PHYSICAL magnets are moving in diff directions, but the FIELDS are still moving in the SAME DIRECTION.... into voidance.
His lens does the same thing, but he has replaced the AIR with a lens AT 21.246 DEGREES....... well, close to it anyway
VIDEO 40 Uncovering the Missing Secrets of Magnetism. GYROMAGNETIC PRECESSION 21.246 degrees
https://www.youtube.com/watch?v=tgjPzC25YI8
TheoriaApophasis
Quote from: d3x0r on August 04, 2014, 03:26:08 PM
I would bet good money that if it were upside down it would rotate the other direction.
nope, same thing.   ..hes using a convex lens which causes one set of mags to be at the precessional angle of 2 contracting spheres of voidance ("attraction")
TheoriaApophasis
I will POST A VIDEO tonight, both DUPLICATING this, and EXPLAINING THIS.
U should like it
>>>>>>UPLOADING NOW.....2 PART VIDEO...........VIDEO 1 EXPLANATION..........VIDEO 2   REPLICATION
;D ;D ;D ;D
