Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
93RDELEMENT
There is hope for you TA !!! just work with the mathematics of mass 1 coulomb of electrons is 1 amp 1mm volt is a coulomb of bosons !!! bosons are at the bottom of a wave function and you cant see them on the OS but there real ................ now the graviton and that is like your picture so your close but its only got 2 vectors of spin you have to many lines of force and there is your error .
mass charge spin discharge ......... movement ........
d3x0r
Quote from: TheoriaApophasis on August 05, 2014, 08:32:45 PM
Just checked again to make sure I didnt have a brain fahrt..........  NOPE,  you're wrong
care to see a video (have to make) of same??
Either
A: you are explaining one thing and SAYING another
B: you didnt test it YOURSELF (as i just did AGAIN)
;D ;D ;D
depends on where you consider the center of rotation of the stick to be... whether to the left or to the right of the short path demonstrated.  If you consider that it's to the left (where the hand is) then CW(stick)=CW(wheel)... but if the stick is tipped outward from the center (to the right of the hand) then CW (stick)=CCW(wheel).
Really hard to say, since it was a short linear path that was used.
d3x0r
Quote from: 93RDELEMENT on August 05, 2014, 08:35:35 PM
But there's no such thing as a stationary electron :)  since all electrons are moving all the time... so there is no 'rest' mass.... so it might be argued they have no potential mass and only kinetic mass.
yes, it's splitting hairs. :)
TheoriaApophasis
Quote from: d3x0r on August 05, 2014, 08:36:38 PM
Thats a bit sophistic.      :o
its a ROD, if i ROLL the rod with the END skywards, the disk rolls in the same direction at i move the rod around a silicone ring
SAME if the ROD is rolled the other way, disk rolls (obviously) in the direction of travel, NEVER INVERSE to travel.
Make a video, your words are a tad unclear.
TheoriaApophasis
Quote from: d3x0r on August 05, 2014, 08:39:55 PM
Pretty sure you and Tinman and CaptZero and few others are the only ones on this board with BRAINS
well put.    ;D ;D
Even TESLA used term "electron" he however DENIED ANY SUCH horseshit that it was a fucking PARTICLE , or "discharge particle"
