Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
gravityblock
Quote from: d3x0r on August 07, 2014, 08:15:26 PM
Re spinning magnet on a convex surface...
if the inner magnet was on a more concave surface, then the rotation would be reversed (compared to previous demos, cw motion of drive magnet will cause cw rotation).
if the curve was exactly the same then it would slide, other than when the driving magnet becomes skewed from the center... then if it's more towards the center, then the rotation will be reversed (drive cw, rotation cw), if it's towards the outside, the rotation will be as has been demonstrated on a convex lens so far (drive cw, rotation ccw)
IF the experiment was done on 2 plates of glass there would be no rotation... so there must be something about the interaction of the curve that allows it...
Magnet that looks for the center of the way (video)
The curve allows a breaking effect of the inner magnet due to how much/less conductive material is over the outer magnet, causing a rotation of the inner magnet.  There is no rotation on 2 plates of glass because the inner magnet will stay centered with the outer magnet and there will be an equal amount of conductive material over the outer magnet (see the first snapshot below and how there is an equal amount of conductive material over the outer magnet, so there is no breaking effect).  Reading the video description may also be helpful.  Notice how the inner magnet rotates around the center point of the outer magnet when they are on the curve (see the second snapshot below and how there is more conductive material on one side of the outer magnet than the other, which causes a breaking effect and a rotation).
Gravock
TheoriaApophasis
Quote from: picowatt on August 07, 2014, 10:49:18 PM
WATCH THIS VIDEO
https://www.youtube.com/watch?v=BHuWloNGo6c&list=UUh3cY-IW8QsEFmAh-TAWwrw
How SuperMagnets are made
NOTICE THE HUGE ERROR AT 10:10  ?????????????????????????
He says   "hit it with a high strength MAGNETIC FILED"    (FAIL!!!!!!!!!!!!!!!!!!!!!!!)
then he says, its hit with :
2400V at 12AMPS
he just called VOLTAGE = MAGNETIC FIELD!!!!!     :o :o :o :o :o :o
VOLTAGE IS TO DIELECTRICITY AS CURRENT IS TO MAGNETISM
With inductance the reaction to change of field is the production of voltage. The current is
proportionate to the field strength only and not velocity of field. With capacity the field is produced
not by current but voltage. This voltage must be accompanied by current in order for power to exist.
The reaction of capacitance to change of applied force is the production of current. The current is
directly proportional to the velocity of field strength. When voltage increases a reaction current
flows into capacitance and thereby energy accumulates. If voltage does not change no current flows
and the capacitance stores the energy which produced the field. If the voltage decreases then the
reaction current reverses and energy flows out of the dielectric field.
TheoriaApophasis
Quote from: gravityblock on August 07, 2014, 11:47:17 PM
Gravock
Thats a cool video, I never thought of that experiment.   Its always the obvious experiments that are simple that are great.  ;D
picowatt
TA,
Why all the disrespect?  I have shown you way more respect than you have shown me (certainly more than you deserve in kind)
Is this your bragged about method of debate?  Just throw a lot of disrespect, condescension, foul language and offensive imagery at your opponent?  I am not impressed...
And just a heads up so you know that you are just wasting time typing, I always stop reading and scroll onward as soon as I see bold type, foul language and condescension in your posts.  There is no need for it.
PW
TheoriaApophasis
Quote from: picowatt on August 07, 2014, 11:53:09 PM
TA,
PW
I see your diversionary tactic to keep addressing the rebuttals to your insane premises.
Wont work.
I only have to REFUTE YOU........not ----
1. impress you
2. convince you
;D ;D
