Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
0 Members and 55 Guests are viewing this topic.
TheoriaApophasis
Quote from: d3x0r on August 08, 2014, 02:27:40 AM
ferroelectric is not ferromagnetic.
You are forgetting that electricity is Phi x Psi   (magnetism and dielectricity).
All polarization is magnetic or transverse Di-electromagnetic,........ is discharge.
There is no magnetic field associated with a ferroelectric, and conversely there is no electric field associated with a ferromagnetic.
actually, there is magnetism associated with any ferroelectric phase,   all electricity is PHI x PSI.
There is no such entity as electricity "without magnetism"
WITHOUT a measurable magnetic FIELD EFFECT yes.........WITHOUT MAGNETISM.......hell no.
Actually (AGAIN) there ARE electric fields associated with ferromagnetic .....ODD YOU MENTION THAT, I was going to demo same tonight using the FERROCELL
There is not one instance of an electric field associated with a magnet, except in your declaration of such
wrong again, ....  what you MEAN TO SAY is there is  ELECTRIFICATION off a magnet sitting on a desk
.....even moving the magnet, you can see the electrification points as the dielectric crosses the magnetic
So, Youre 100% dead wrong on that one.   ;)
Simply MOVING ANY MAGNET in space and time creates electrification,  JUST the magnet.
Dont you know that the mere movement of a magnet in space and time causes the divergent magnetism to interact with the dielectricity concentrated at the inertial plane??????
:o :o :o
FOUR primary dimensions in electrical engineering. These are:
1) Time
2) Space
3) Dielectricity
4) Magnetism
ANY FING magnet already has the DIELECTRICITY AND MAGNETISM......
all you have to do it MOVE IT IN SPACE AND TIME.
add a dielectric reflector (coil,  duhhhhhhh), and you couple off that MUTUALLY in both.
.....................>>>>>>>However the MERE MAGNET itself produces electrification IN MOVEMENT<<<<<<<<<<......................
What did you THINK all those copper coils were COUPLING OFF OF????????????????
Haa!!
SO, thanks for that INTRO TO VIDEO #52 !!!!!!!!!
Where is my INSANE LAUGHTER PICTURE AT???
I can show you electrification simply by moving a SINGLE MAGNET in space and time using a Ferrocell  :o :o :o
Yes, thats right.............you heard me.
.....YES, you get electrification simply by moving a SINGLE MAGNET in space and time.........OR, as I call it ........."the important shit they DONT TEACH YOU IN SCHOOL"......
d3x0r
Quote from: TheoriaApophasis on August 08, 2014, 02:45:25 AM
correct.  I made sure I never used the word 'electricity' but rather electric field...
TheoriaApophasis
Quote from: d3x0r on August 08, 2014, 03:10:41 AM
VIDEO uploading now, all those BLURRED smears where the dielectric meets the magnetic in a MOVING MAGNET is electrification
move any magnet in space and time, and its magnetic interacts with its dielectric
see example of same "blurs" below.
its not "my view", its empirically measurable electricity .....,  however obviously, moving a magnet slowly by HAND is not going to POWER anything.
d3x0r
Quote from: d3x0r
No, both are in a static state and there is no electrification.
.....even moving the magnet, you can see the electrification points as the dielectric crosses the magnetic<<<<<<<<<<<<
Dont you know that the mere movement of a magnet in space and time causes the divergent magnetism to interact with the dielectricity concentrated at the inertial plane? ??? ??
:o :o :o
No motion involved.... you're changing parameters
1) Time
2) Space
3) Dielectricity
4) Magnetism
(yes everything is moving, but magnetic induction in a coil requires relative motion to each other... even though we go around the galaxy some  483,000 miles per hour{a  6 ft wheel needs to turn at  187,312 RPM to go that fast on its circumferance...} doesn't matter if they aren't moving relative to each other  ... "and how fast is the Milky Way Galaxy moving? The speed turns out to be an astounding 1.3 million miles per hour" )
moving magnetism in space causes dielectricity; I'll agree... changing dielectric field in time causes magnetism...
I cannot guarantee that you can move in space without moving in time, since a motion is dp/dt which involves automatically 2 quantities
a changing dielectric field does not occur in space, but only in time... longitudinal... and results in a magnetic field in space.
I suppose you'll argue there's anti-space (counter-space) which is where the supposed dielectric charge is discharging to... but what replenishes the charge?  something from a 3rd anti-space?
Why can't a magnetostatic field exist without dielectric field?
Why can't a electrostatic field exist without magnetism?
They both can... in a ferromagnetic and in a ferroelectric.... or in a closed inductor of superconducting material, and a open ideal capacitor.
If there is no electron, then there's no reason to think that the super conducting closed loop has a current and hence no dielectric discharge... there is no voltage drop across an inductor.
current might just be an alignment of magnetic moments.  crossing a spark across a gap would just be a cavitation of ether at sufficiently high voltage...
https://www.youtube.com/watch?v=GyT1dsY0KtA  (aka sonolumenscence; because experiementally it's generated with sound in water in this case)
https://www.youtube.com/watch?v=GQ8iRMGnb1g (longer video; J.Verbelli... vortex, Russell, etc... eventually cavitation)
Esp. since it can happen in a vacuum...
but I digress with only a poorly formed hypothesis (half{or less}-baked).
I'd like to see how you detect that
d3x0r
Actually tesla's work was to get a 0 time change in magnetic and only a motion in space... but just moving a magnetic field in space without time should cause induction; again conversely to changing a dielectric field in time and no space....
there is a voltage drop/raise in an inductor when charging and discharging.. but I was referring only to the static states.  Without a solid foundation you can't build a solid anything.
