Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
TheoriaApophasis
Quote from: SeaMonkey on August 09, 2014, 07:50:45 PM
93rdElement,
You're of course entitled to your opinions, no matter how
obtuse.  Your level of hyper-stimulation is puzzling, however.
Koolaid?
Sok,  you should see the private message he sent me,     hes communicating with Lord Xenu on planet Omicron-Theta
;D ;D
gravityblock
Quote from: TheoriaApophasis on August 09, 2014, 08:14:20 PM
;D ;D
Private messages shouldn't be repeated in the public forum!
Gravock
TheoriaApophasis
Quote from: gravityblock on August 09, 2014, 08:52:49 PM
Gravock
thats not what he said,      so i didnt communicate ANYTHING,   point is, hes nutz.
You dont need a private message to see the OBVIOUS     ;D
93RDELEMENT
Hutchison is using a crystal lens ! there is a connection with the lens and gravity ,we know that light gravity and a stream of magnetic particles all interact and can be changed with RF signals . But the TA pictures don't represent any vortex he cant make the holographic image spin ..... But the geometry is the same as space time fabric and to us that is the only point of interest not all the mad science he paints all over the image that bit is nuts .......The sad thing is he will miss the connection and see it as something that it is not and the spinning magnet over the lens is electron re coiling not a vacuum or a dielectric event as there is no charge to discharge ...
Free electrons between atoms like in copper wire or a neo magnet cant leave the boundary of the surface atoms they are trapped by there own opposing field and form a diamagnetic pressure inside the mass of the magnet ... Where there is pressure there is energy and an interphase between the fabric of space which is it self gravity can loop like string in the lens set up .... The magnet spins at its centre just like a black hole an electron has the same inverse law of a black hole ... If the magnet was the black hole and space time curvature was the lens and the magnetic field is the light around the black hole than the electrical charge of the black hole must come from the mass that is stuck at the event horizon ...... But the comparison is not the same as there is no charge in the lens system and the photons are only following the line of gravity not the MF .....
The only thing that can make the magnet spin is another magnet that is moving ccw to the direction of the spin so the only available component that can do that is the free electron being drawn into the centre releasing energy and traveling back to where it cam from.
The grand unification law of the unified field that is now the leading model in cutting edge quantum mechanics is proved correct in the lens set up as there must be a string that connects the mass of the lens the free electrons and the magnetic field .........................................
The lens is the connecting component like a link in a chain or a knot tied between 2 or 3 strings ! TA is so stuck on the dielectric that he will try and stick it to everything he does its nuts ........... Now the only thing to do is except truth over bullshit  and make the magnet levitate and spin at the same time ! And to do that you need to add a 3 phase signal from another lens .........
Its all string but not a vortex in sight TA must spin hes pretty hologram but he can never do that so that to us is a folly which is a building that has no purpose just like he's daft vortex .... Nice hologram interesting how the photons refract the vectors of the lattice electrons in the lens that's the outer electron in the atom of the bond in the glass .. So the light appears to bend but its just a trick of the light ,,,....
Reality over bullshit ........ NOW STICK TO REALITY BECAUSE EVERY SCIENTIST ON THE PLANET WILL AGREE WITH ME NOT TA ..............
ME
SeaMonkey
Quote from: 93rdELEMuNT
...EVERY SCIENTIST ON THE PLANET WILL AGREE WITH ME...
Your bottom line is revealing what drives you.
