Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
0 Members and 73 Guests are viewing this topic.
TheoriaApophasis
Quote from: Acca on August 13, 2014, 11:55:39 PM
Acca..... :)
comments to PICS below:
James Clerk Maxwell's "idle wheel" analogy:
Below: I only recently came across J.C. Maxwell's vortex analogy and 'idler gear' comparison, which mirrored mine, except J.C. Maxwell did not grasp that unlike a mechanical idler gear which plays only a passive-effective interactive part in movement, the dielectric inertial plane, or 'idler' gear is the actual mover, the driver, so to speak. As is necessarily, logically, and absolutely the case to which dielectricity is by nature, being inertial, counterspatial, and creating magnetism as an Ether-modality in the discharge of itself. Also unfortunately J.C. Maxwell, while a strong supporter of the Ether, makes an Atomistic comparison of the "idler" gear of vortex reciprocation.
Below: On left redrawn correct analogy of dielectricity as the inertial driver (inverse to mechanical 'idler' gears). Middle and right are mechanical idle gears which mediation a passive-interactive role in movement and mechanical reciprocations.
Below: My discovery and formula for magnetic reciprocation given a perfect situation. To add to J.C. Maxwell's analogy, as I have discovered, that unlike machines, the "idler wheel" of what is 'driving magnetism' is the stationary inertial dielectric which is the prima causa, the Prime Mover of magnetic reciprocations; just the inverse to a mechanical 'idler gear'. This is the fundamental nature of dielectricity being the 'electrical inertia', and fundamental Ether-modality from which the other 3 are derived.
TheoriaApophasis
Acca..... :)
Keep experimenting, everyone else can kiss your arse,    ...    they flap their lips.  ;)
sierraloewe
TheoriaApophasis: did you build your ferrocell yourself?  Where can I get one?
TheoriaApophasis
Quote from: sierraloewe on August 14, 2014, 11:04:53 AM
I assembled mine from the lens foundation
you can buy EITHER assembled, or just the lenses with the ferrofluid (special mixture) HERE:
If you want to build it yourself, I can tell you how,  but either way,  go here:
http://www.revolution-labs.com/Handmade-Ferrofluid-cells/b/5244658011?ie=UTF8&title=Handmade+Ferrofluid+cells
(NO, i do not get any kickbacks for recommending you or anyone for a purchase from M. Snyder)
Hes a nice guy, and all his cells are precession hand built with a good bit of labor in their construction.  ;)
You can get the "PRO" LED light assembly from LOWES/  Home Depot for $40
that would be RGB LEDS with a remote control, and also the VERY bright white "extension set" made by another company, ....all sold at Lowes  (and Home Depot too if I recall).
93RDELEMENT
As stated the flow of particles is the driving force not the magnetic lines as they only trap the flow of particles to produce the direction of speed for the wheel ! In what Maxwell has started confirms this I do not see an extension to the said Maxwell definition as a new discovery you have made ????? Maxwell latter in he's life formed the foundation formulas for the vacuum not a magnetic vortex ! A vacuum to which acts like any vacuum a flow of particles in and out ...  I except that you have chosen an early discretion of Maxwell's work it would be a good idea to also consider the final formulas of the vacuum that is the final work of Maxwell .. To only turn a single stone among many and claim you have found what no other has found is questionable but interesting .
In our research we isolated a zero point magnetic 2.2kw motor at 4000 rpm ! The room in which it is operated in gets cooler the longer the system runs ! This would only confirm a vacuum not a vortex as a vortex would increase to flow and temperature of entropy . As my college has stated to in previous text a vortex requires entropy to grow that is the excepted standard in international physics not quantum mechanics ! Please place your system in a closed insulated box if the temperature is increased you will confirm the said vortex and yes that would be a new discovery ..  If the temperature is decreased it is a vacuum and as said and confirmed in Maxwell's laws for the vacuum ! Maxwell's work and much latter after he's death formed the foundation of the now agreed zero point field !
Now we see you including time and space you will start to see the infinite mass which is always a condensed form of energy entrapped by its own vacuum not a vortex in sight ! Entropy will be the only form of indirect method to calculate such results, not a make it up as you go theory with your own formulas please use existing standard mathematics or it will not be excepted by us or any other independent that is now looking at your claims ! You are here in a public forum not an institution whom only dance to your logic so except some criticism detailed observations and a new and fresh perspective !
To us our aim is to isolate these particles and so far we are close to confirming them as bosons and gravitons , not a new type of particle just the ones we expected to see in many different combinations of technologies now being made all around the world ! There are many whom don't publish and one group we know in Israel have made outstanding advancements in holographic technologies with magnetic lensing !  To claim a discovery in this field is going to take a long time and a lot of talking with final proof confirmed by more than one independent observer ! Also the r would be many counter claims to the said claim !
Be advised on this and don't get so up set when others give facts that you wish not to consider in your claims or your reputation it self will hold a black mark of chaos over a non reality with a personality that will be ignored !
But having said this we appreciate you coming forward with your work and would like you to consider publishing it in a physics journal for correct and open debate among the real physicists of the science community !
Yours truly
Head of the earth science team
Captain cave man
