Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
0 Members and 23 Guests are viewing this topic.
TheoriaApophasis
FLIR  ,  thermal IR
Hmmm, is that a 6" giant neodymium that has NOT been touched in days just "sitting there" hotter than the environment???
YUP
Is that thermal reflectance?   Nope.
The object sitting there not moving is SPINNING at tremendous speeds.  ;D ;D ;D ;D ;D
TheoriaApophasis
FLIR,
showing more light being 'sucked' in along the dielectric inertial plane
more light, more heat
I made these pics tonight
TheoriaApophasis
Well, nobody has EVER seen a magnet doing this before
2 part video series........
https://www.youtube.com/watch?v=qZJvIMU7JYM
.................Better yet, i EXPECTED THIS to happen before doing it.    ;) ;) ;) ;)
Lux et Veritas
93RDELEMENT
Your getting closer ! But where are the temperature values ?????? Also alpha particles will be attracted to that magnet and that will change temperature all kinds of radiation will be attracted to it and that will throw you way off the button !!!! Glad to see entropy its about time !!!
Check out the current to earth ! Place a wire from the magnet to a long copper rod in the earth !!! But there is no sign of entropic movement but think boson to graviton as the vortex particles not the magnetic field ... You will need to detect them and there spiralling vector ! The only way is to take a entropic measurement in water for entropy it should be stable and at unity ! WEIGH IT WITH AN ATOMIC SCALE in and out of the water .... And the frequency of its mass will show particle interaction ! The frequency at the centre to the frequency on the OD of the magnet will be slightly different if there is a vortex .... BUT ITS NOT A MAGNETIC VORTEX IT WILL BE A SUB ATOMIC PARTICLE VORTEX OR THEY WILL NOT LISTEN TO YOU ................
That is a big RED so it will be challenged and if you are tweaking the pictures your get stuffed faster than a turkey in a homeless shelter set up for nut jobs and runaway con men !!!
If you want to win you must not cheat and it must be the same measurements for an out side independent using the same set up ! But at the end of the day it looks like a simple vacuum ! Maxwell went from vortex to vacuum than died ! Nothing wrong with a vacuum ! I want to final the number of particles in that vacuum thanks for the pictures ....
I can do that just by looking at your picture can you ?????????????????????
me
TheoriaApophasis
