Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
0 Members and 46 Guests are viewing this topic.
d3x0r
Quote from: TheoriaApophasis on August 19, 2014, 02:07:27 AM
uploading new video on "flat surface" as per your request now.
beat ya to it :p :)  some things I can answer for myself...
Hmmm nope don't get it... well maybe, if the spin of the field is also accounted, then maybe I dunnno it ended up backwards in the pipe condition
picowatt
Quote from: TheoriaApophasis on August 18, 2014, 11:52:08 PM
Fallacy, prick.      ::)   ;D
  the FLIR is "seeing it"      thats a FLIR SHOT,   not my eyeballs.
This is pointing the FLIR AROUND THE CORNER, SO BODY HEAT REFLECTANCE IS IMPOSSIBLE,.......my entire body is unexposed to that room during the shot..>>>>>>>>>>>
also no lights on in that room EVER,  very late at night in total darkness.
you lose.
TA,
So what, exactly, do you disagree with regarding my post discussing your FLIR video?
You talk of a "fallacy" but address nothing I discussed directly.  Surely even you must agree that at 0:20 to 0:21 in your video the magnet, holding fixture, and CRT are all indicated by the FLIR as being at the same relatively low temperature.
Do you believe that the reflective surfaces of the magnet and CRT spontaneously or magically began emitting heat based on where the FLIR is positioned?
Your video provides no evidence to support any of the claims you state it does, and in fact, totally refutes your assertions.
PW
TheoriaApophasis
Quote from: d3x0r on August 19, 2014, 02:16:55 AM
I know you get it.  ;)
Your idea was good, and I acted on it, ....just for myself for others, and also I added the explanation.
TheoriaApophasis
Quote from: picowatt on August 19, 2014, 02:25:49 AM
This is pointing the FLIR AROUND THE CORNER using an extension on the FLIR, SO BODY HEAT REFLECTANCE IS IMPOSSIBLE,.......my entire body is unexposed to that room during the shot..>>>>>>>>>>>
Heres what, son, buy your own FLIR, post a video proving me wrong.  Ill watch it.   ;D
You produce jack shit.    The ancients called your type an "Eel wriggler".
In ancient Prakrit they called your type a "snake tongue",   it... "sticks out a couple inches and snaps at you but poses no harm, but fear in fools" - Udana
Grab onto logic son, radiation = heat = discharge.
How much radiative HEAT in centrifugal magnetism?  Not much at all, not even enough to power an ant fart.   But, as necessitated, it IS there.
NOW, tell us WHY the CATHODE FREEZES WHEN THE ANODE GETS HOT
do you know why?   I seriously fucking doubt it.
picowatt
Quote from: TheoriaApophasis on August 19, 2014, 02:49:07 AM
TA,
Did you even read my post?
You have not responded to any of the points I raised in my post regarding your "magnet against the CRT" FLIR video.
I take it you disagree with my observations and conclusions regarding that FLIR video, yet you refuse to discuss or even mention exactly what it is you disagree with.
Regarding the static image you posted of the neo on the floor apparently at a higher temperature than its surroundings, there are two things that must be considered and ruled out before any conclusions or extraordinary claims can be made.
First, with regard to reflections, did you pan about the room looking for any thermal sources of similar temperature? (that is, the ceiling, walls,  windows or any objects in the room)  The room could appear completely dark to the human eye, but without using the FLIR to completely investigate any possible heat sources dissipating at a similar temperature from objects in the room or diffuse heat sources shining thru the open door you aimed the FLIR thru, there is no way of knowing if the observed temperature was due to reflections or not.  Painting the surface of the magnet ultra flat black or covering it with some other IR non-reflective material would reduce reflections to a degree, but even doing that would require careful measurements to determine the effectiveness of that reflection reduction method.  Longwave IR will reflect nicely off of many objects that appear non-reflective in visible wavelengths.  Even placing the FLIR in an otherwise dark room can cause the heat dissipated from the FLIR to produce a diffuse IR glow within the room.  An alternative method to investigate whether the indicated temperature of the magnet is due to reflections or not would be to place a similarly IR reflective object located close to and in the same plane as the magnet being observed.  If the observed temp is related to reflection both objects should show the reflected heat similarly.
The second thing that must be considered is the large thermal mass of the neo magnet in the image.  It is possible that the room wherein the magnet was located had been slightly warmer earlier in the day, or that the sun might have been shining thru a window onto that area of the room.  The thermal mass of the magnet would dissipate its stored heat for quite some time compared to the lower thermal masses the magnet rests upon.  In other words, the magnet may have not yet fully cooled from some earlier temp increase compared to its surroundings.  Again, no conclusions should be made until this is ruled out.
Did you make a video of the magnet resting on the floor at the apparently elevated temperature?  When making FLIR videos, the true temperature of an object will not typically change when the FLIR is panned toward that object from different angles.  Any changes in indicated temperature that do occur when the angles change is typically due to changes in illumination angles from IR sources being reflected from the surface of the object, and not the object itself changing temperature.
PW
