Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
0 Members and 55 Guests are viewing this topic.
TheoriaApophasis
Quote from: picowatt on August 19, 2014, 03:54:04 AM
Did you make a video of the magnet resting on the floor at the apparently elevated temperature?
RIght, because heat doesnt rise, it sits at the ground.
No, wait....uhmmm.   ROFL
Go buy a FLIR, make a video,  then kiss it where it doesnt heat from the sun doesnt shine.
Youre nothing but a sophist.
TheoriaApophasis
author=d3x0r
Been testing my "programmed" BISMUTH discovery.........., it will do SINGLE DISK levitation at 11 to 15 mm higher than standard melt-pour bismuth disks will.
great stuff.
just a starter pic below, then i removed the cloth and did exact measurements after confirming my suspicions.
Quote from: d3x0r on August 19, 2014, 02:03:09 AM
magnet does rotate on a dielectric with the pole against the diamagnetic...
https://www.youtube.com/watch?v=1ErwCvY7E0o
at least it does have a strong tendancy too... without being on a curved surface, so the point of contact doesn't really apply...
You are missing the most important part of your demonstration, because you have been blinded. Or rather, dazzled by the glare of useless reflections of a wasted genius.
You are even unable to see just _why_ your magnets rotate, because you are performing _demonstrations_ rather than true experiments. Let's see if you can observe what is happening in _this_ video and explain it.
http://www.youtube.com/watch?v=bas00qdj6Xc
Quote from: john_doe on August 19, 2014, 02:03:52 AM
Well looking at that pic I'd say that adds to your theory.
Those that have actually read Einstein's theory of relativity shouldn't have forgotten the first few chapters; Looking at something differently gives you a different perspective. In actuality, both views are usually right. At the very minimum these theories shouldn't be met with such distaste. Instead we should be applying them throughout the Solar System to see if they work on the large scale. Eliminating particles altogether because they're yet more theories.
This is what they're saying about Saturn;
""The hexagon is just a current of air, and weather features out there that share similarities to this are notoriously turbulent and unstable," said Andrew Ingersoll, a Cassini imaging team member at the California Institute of Technology in Pasadena. "A hurricane on Earth typically lasts a week, but this has been here for decades -- and who knows -- maybe centuries."
Weather patterns on Earth are interrupted when they encounter friction from landforms or ice caps. Scientists suspect the stability of the hexagon has something to do with the lack of solid landforms on Saturn, which is essentially a giant ball of gas."
So something that is nearly perfectly round, in-comprehensively large to humans (9x size of Earth), doesn't have any landforms, gives a spectacular view of reflective sunlight, has a storm moving 24x7x365 exactly as TA has predicted?
Eventually this theory will be proven right.... Although I hope when scientists eventually do, their peers don't react in the same negative manner.
You may be interested in these images. The first is comparing a simulator result to the actual polar vortex on Saturn, the second is from my laboratory:
picowatt
Quote from: TheoriaApophasis on August 19, 2014, 04:15:37 AM
TA,
You claim I am a sophist, but it is YOU that most always responds to my posts with sophistry, strawmans and insulting tones, just as you do in this and your previous replies regarding my FLIR discussion.
Again, you have addressed none of the points I raised in my posts, nor have you expressed just what it is in my post that you disagree with.
Apparently you do not understand why I asked if you made a VIDEO of the magnet on the floor.  I thought you were smarter than that.  I even explained why I asked
Being unable to admit being wrong now and again is a crippling trait for any experimentalist.  It sadly breeds a closed mind.
PW
