Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
0 Members and 67 Guests are viewing this topic.
Timnan:
Feel free to contemplate your experiment and my hint.  I will give the answer tomorrow at about the same time.  If somebody chimes in and offers up a good explanation I will respond in turn.
Little puzzles like this are fun and good for the noggin.  If you don't get it by tomorrow, hopefully my explanation will make sense to you.
tinman
Quote from: MileHigh on July 19, 2014, 09:26:20 PM
Tinman:
I am pretty sure that I figured out the explanation for your test.  I only watched the first four minutes of your clip but I think I get it.  If you flip over the magnet or if you reverse the polarity of the voltage then the vortex changes direction, correct?   (oops not sure if you changed the voltage polarity because I am not sure if the metal will react the same way and still produce bubbles.)
I will give you a hint.  Think about the example of the CRT test in one of Theoria's clips where he points the magnet straight at the monitor.
P.S.:  It appears that Theoria can't explain your neat little experiment either and served up a small word salad instead.
@MH-and TK if your still watching.
Could you please take the time to watch all of the video-i think it's needed.
MH-if i swap the polarity over,i get no bubbles from the magnet's,and the copper oxide from the copper plate starts to flow over to the magnet-and we start to coat the magnet with copper,as we know will happen with electro plateing.
I do not know 100% as to what effect the magnet has or is doing in regards to the CRT screen,so telling me to think of that as an example is just sending me deeper into the forrest lol. So a clear explination would be really helpful here-i mean,this is how we learn.
As the electric field is uniform around the magnet(via the current carried by the water) i have to eliminate the effect that causes a homopolar motor to work. To me it seems that the magnetic field has an effect on the hydrogen atoms spin direction :-\,as we are only producing hydrogen gas around the PM.
Next i am going to try an electromagnet,to see if a near electric field has any effect on the spin effect we see with a PM. ???
Captain Zero:
In a virtual sense, you don't realize that you have on thick glazed glasses that make you look like there are two eyeball-sized spheres on your face.  It's that bad.  You spilled your beans there but I already knew it.
I will repeat:  DO NOT try to imply in any way that I am evil or MIB.  I will not tolerate it because there are safety issues to consider.
TheoriaApophasis
Quote from: MileHigh on July 19, 2014, 09:49:47 PM
Please explain what is going on in Tinnman's clip in your own words right here and right now or simply admit that you are unable to explain it.
I can see you have no idea that you're speaking to someone far far far better skilled at seeing fallacies, loaded questions, and 'honeypot loaded questions'.
I did explain it pages ago, I did explain it in the book.   Go look it up yourself.     You're a lazy keyboard jockey son.   ;D
Hydrogen bubble vortex magneto-centrifugal edge movement as it raises to pressure gradient equalization (as a gas) in the water he has it in.
diamagnetic H2 bubbles running in flow with centrifugal high speed magnetic vortex flow.
I can do the same thing with charged graphite dust in suspension.
likewise with BISMUTH DUST (with no electrification needed of course)
Tinman:
I will try to get through your clip but I can't guarantee it.  This thread is not super-huge at this point and the clue should not be too hard to find.
All will be revealed tomorrow if nobody gets it.
