Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
0 Members and 90 Guests are viewing this topic.
gravityblock
Quote from: TheoriaApophasis on July 20, 2014, 01:26:03 AM
Middle of august, there is a ton of content to add.
As for momentum dump,  still trying to figure that one out, only ideas.
I know it can be done!  The water in a singing bowl won't rotate in the direction of the wand until a critical value has been reached (video).  Once a critical value has been reached, then the water will very quickly begin to rotate in the direction of the wand.  Reversing the direction of the wand causes the water to reverse it's rotation direction with the wand instantaneously.  This behaviour is similar to a super-fluid!  This is just a proof of concept.  Now, the question is how to transfer the whole momentum to a lighter object!
When a super-fluid is rotating uniformly with the container, the rotating state consists of quantized vortices. That is, when the container is rotated at speed below the first critical velocity (related to the quantum numbers for the element in question) the liquid remains perfectly stationary. Once the first critical velocity is reached, the super-fluid will very quickly begin spinning at the critical speed. The speed is quantized, that is, a super-fluid can only spin at certain "allowed" or critical speed values. In simplified terms, if the container is rotated to a certain allowed speed, the super-fluid will rotate very quickly along with the container, otherwise, if the speed is too slow, then the super-fluid will not move at all.
Gravock
tinman
It would seem an electromagnet dose not have the same field properties as a PM.
It seems that electromagnets fields are different to that of a PM fields-no spin :o
Video uploading now.
TheoriaApophasis
Quote from: tinman on July 20, 2014, 02:56:10 AM
nope, it wouldnt because .....
A: electromagnet is "driving" the magnetism via electricity, NOT dielectricity from the inter-atomic made coherent into the incommensurable geometry of the PM
B: Electromagnet is spatially divergent IN/AS a coil, and does NOT (almost the exact opposite) have the properties of dielectricity
TheoriaApophasis
Quote from: gravityblock on July 20, 2014, 02:47:38 AM
Gravock
Preaching to the choir, I agree.
I made a discovery using an experiment with magnetism and water in the 3rd edition that will make your head fall of your shoulders.  ;D
I know nobody else has seen it .
tinman
Well here is my second test. This time using an electromagnet insted of a PM. There is no spin detected with the electromagnet,unlike the PM that shows a clear spin at the pole's(Im using the terms north and south pole's,as that is what most people understand)
So why no spin with the electromagnet ,that is placed in the same situation???.
https://www.youtube.com/watch?v=UIlijUSJMmg&list=UUsLiBC2cL5GsZGLcj2rm-4w
