Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
0 Members and 49 Guests are viewing this topic.
93RDELEMENT
Experiments that have nothing to do with a vortex or the vacuum that creates it is pointless ! All theories so far are all flawed endeavours to identify the reality of such work ! Please stop referring to faraday he is an old book on the out of date book shelf ! The so called ultimate proof of a vortex is with a working model that has substantial energy gain not just a silly wire and some magnets . But it does prove the outside force is independent from the modal .
Now I have a 10kwh magnetic vortex zero point generator and no I don't do videos or have a need to explore other experiments ! So MR MILE HIGH come back down to earth ! One can never determine all the facts if they fill they know it all and have no technology to produce an event that will completely confirm a true vacuum vortex . A few magnets wont do the job correctly and will serve very little purpose as there is nothing you can do with it ! Sorry to bring you back to the ground level of reality where I can ASURE YOU that a fully operating system will set you running out the door ...
Your tone is some what aggressive and you write in a manner of someone that may be high on something ? Calm down sir or you will blow a fuse ... Now give me good reason why you deserve to know how a 10 kwh vortex generator is made or how it works and I do mean at the particle level . To many here write in  a way that portrays a mind of experience and refuse to except fact over fiction by demonstrable effect, to that I challenge you .. Throw away the stupid out of date physics book and all reference material date ect And allow me to place in one hand a 5.5 inch ferrite magnet and a special motor in the other hand as the magnet draws closer to the motor the speed of the motor will increase .. That's lesson one !
Lesson 2 is to achieve the same effect but the current will decrease to zero point as the magnet gets closer to the motor.
Lesson 3 Is when you disengage any power supply and the motor is still running .
Lesson 4 Is when the gravity of the combined device is coherently isolated and the apparatus is suspended in an animated form of its new gravity bubble .
Lesson 5 is HEALTH AND SAFETY !and the most important lesson because the technology floods dark energy into the gaps between electrons it would be wise not to stand in the flow of that field ...
So come on down to earth ! STOP PLAYING WITH TOYS ! Your talking to me now and I sir am the best that there is and ever will be !!! who am I ? I am the master of the vortex ! That means you are my student ! You have one chance so quickly learn the art of how to be humble sincere kind and courteous honest and not just fearless or pumped up so high with your own words that you will only ever see the dark between the light ...
Some of us are the true masters of this universe and I am one of them !!!! Now start again !!!
Yours truly
The one that is going to rock your planet LOL XXXXXX
Farmhand
How is the rising bubbles forming a swirling pattern any different to the rising smoke and flames from a fire causing a swirling pattern ?
I think it is the natural tendency of fluids rising in other fluids to do that.  I make fires that produce some real nice vortex patterns
quite regularly.
It is my belief that there are some odd things that go on inside a strong vortex like a tornado, I see stuff get propelled directly
upwards inside them at times, seemingly not caused by wind but by what appears to be a negation of gravity combined with
pressure differences. I see things go straight up like they get launched, with sometimes no spinning until the object contacts the
inner wall of wind. It just looks odd and not caused by wind generated "lift".
wattsup
Quote from: tinman on July 19, 2014, 09:12:34 PM
Wattsup-did you watch the video?. If so,can you explain as to why we get zero spin when i use the piece of pipe that has no magnetic field,and as soon as i add a magnet to that very same piece of pipe,we get a very clear spin. Why dose the spin direction change when flipping a magnet over-the very same magnet,with the very same shape?.
The magnetic fields are needed to create the spin,there is no doubt about that.
@Tinman
The strength of your neos is very strong and yes there could be an effect of spin, but let me suggest this small test.
1) Find a masson jar or other smaller glass container then your water tank.
2) Put the anode/cathode in the jar and add your water.
3) Produce your micro bubbles in order to saturate the solution as much as can possible to create a clouded solution.
4) Remove the anode/cathode.
5) Find a little non-magnet whatever and put it at the bottom of the jar to act as a raised platform.
6) Put your magnet on the platform.
7) Take a close up of the top of the magnet.
Logic: If the magnet is the sole instigator of any spin, it should not care where the bubbles come from. Whether they are produced and rising from the sidewall then curving back in towards the top of the magnet or whether the solution is fully saturated with bubbles, the magnet should not care and you should till see spin to some degree.
So by removing all other contributing factors the affect should not change, so such a test would be very revealing.
wattsup
Tinman:
Just some pointers.   The current inside the aquarium flows throughout the entire body of water.  So that's why moving the ring did not make a noticeable difference.  Naturally most of the current flows in the general volume of water in line between the magnet and the ring, and much less current flows into the corners of the tank.
Look at the attached graphic. Imagine that you are above the magnet looking downwards.  You are looking at a horizontal slice of the water a few inches above the magnet.  The magnetic field lines are going downwards into the page and they go into the top of the cylindrical magnet.  The charge q represents a small slice of a spaghetti strand.
For the graphic you have to do a swap - you see the red force arrows and the and the green velocity arrows.  So if you swap the velocity and force you have current moving inwards towards the magnet, and force in a radial direction.  Look at how the green force vectors push on the water to create a vortex.  That is an example of the type of thing that is happening in your experiments.
Here is another "view:"  If you are looking at a ring on top of the "mushroom cloud" you can imagine that at a certain point in space for the ring the magnetic field is horizontal and extends radially outwards like the spokes of a wheel.  In this case lets imagine the current is going down into the page.  One more time the magnetic field and the current are at right angles to one another and you get the same radial force vector pattern that creates a vortex in the water.
Captain Zero:
How is your AIDS coming along?  Are you still getting the dizzy spells?  Has it started to affect your vision?  Your weight was way down last year but has the new drug cocktail made a difference?
I know that you have been coping with it for years and I suppose that you are fortunate because you still have your mobility.
I know it's tough but hang in there, they may have a cure one day.
