Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
0 Members and 64 Guests are viewing this topic.
sadang
@profitis
For me this image seems to show a bottom part of a vortex funnel. But the image is really unclear and is hard to make a correct interpretation. I'll try to reproduce this kind of experiment using my own setup and I'll be back with the results.
joel321
TA, I was dreaming today wondering what is causing the MAGNETIC FIELD in the EARTH and comparing it to the magnetic field in your typical hand held magnet.
A typical hand held magnet comes from the ground or is made by manufactures with a high current jolt.  Like a HDD magnet, that magnet is not to be found in the natural earth BUT there are magnetic rocks all over the earth.
So I ask myself many questions, for one, how can the earth have a magnetic field DUE to magma (molten lava in the core) while your typical hand held magnet does not have a molten core?
Then I ask myself, does the earth's magnetic field have a vortex too?
Then I ask myself, what is the magnetic gauss of the earth's magnetic field? Can we even measure it with our instruments or can we just guess?
Then I went in to thinking that the UNIVERSE is like the sea. Like a fish swimming in outer space. Even meteors just "floating" in outer space. Then I wonder why do rocks sink in the ocean and what rocks don't sink in the ocean? Well because the outer space  must be more DENSE? So then the meteors in outer space must be less dense than OUTER SPACE. So then I come to the conclusion that the outer space is very very dense than the floating rocks in space. ok.
Now the following is very interesting in my mind, what keeps the earth up float in the same place in a geometrical manner and not just float all over the place all dumb all over? My conclusion is that the ATMOSPHERE along with the magnetic field is keeping the earth afloat. This means to me that the outer space is not a PLANE but rather AN OCEAN (I find it hard to believe that the earth is sitting on a "blanket" of space like albert einstein suggested). The earths atmosphere is keeping the planet afloat "OUTER SPACE" while the earths heavy rock in the middle is what is keeping it from just going up and up like a balloon filled with helium, or from sinking down a "black hole". And then we have the magnetic fields that make it spin adding to the stabilization of the earths' (or any other planet) stability around the sun.  Moreover, the vortex has some play in it.
Lots to think about so little time right. But not that hard to come to a COMMON sense.
So to recap:
What is causing the magnetic field in the earth?
What is causing the magnetic field in an earth rock (magma)?
Does the earth magnetic field has a vortex?
What is the magnetic gauss of the earths magnetic field?
Why do rocks sink in the ocean and not sink in outer space? (outside the atmosphere) Any rock from earth 'floats' in outer space right?
Too many questions, so little time to find out lol, but at least I would like to learn a few of them with out those dumb asses getting in the way. :)
profitis
sadang:'
@profitis
For me this image seems to show a bottom part of a vortex funnel. But the image is really unclear and is hard to make a correct interpretation. I'll try to reproduce this kind of experiment using my own setup and I'll be back with the results.'
You have a lab sadang? You will have to get the colliod just right to be able to see this effect.play around with it until you get it right.formaldehyde/sodium sulfite in solution is a powerful reducer.use only small amounts,no heating required.do it in dilute gelatine solution if you want yellow invisible colloids.do it with less gelatine or no gelatine for larger visible silver/black colloids.dilute the as prepared colloid for pattern visibility as required.it takes a few hours resting infront magnet before patterns emerge out of random chaos.I've still got swirlys in my colloid.just waiting for better camera now
profitis
I imagine a bismuth colloid would give even better results but all my attempts to keep bismuth in suspension without co-agulation failed
sadang
@profitis
No, I don't have a lab, my lab is my own home. I'll try to use just pure distilled water with suspensions of pure silver, to visualize the diamagnetic proprieties of silver particles interacting with magnetic field. I'll not use chemistry but electricity to get the silver particles. I believe you get swirls in the colloidal solutions, but let's go deeper with analysis and interpretation, taking into account the already known effects. Btw, where did you placed the magnet? What shape it has? What polarity did you used against the colloidal silver solution?
