Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
TheoriaApophasis
Quote from: joel321 on February 24, 2015, 12:15:13 AM
TA, From all of your images that I've seen I conclude that the vortex is just a "bond" of anything. I only see that the vortex is just a way of containing a any wave.
A vortex is ultimately just an expression of a TETHER,  like that old exercise toy where you whacked a ball on a rubber string that went out and came back.
everything in the cosmos is on a tether.
Birth and death, discharge and charge.............shot and recoil.  etc.
As a matter of fact, if there was not vortex, everything would ether go up or down for infinite if I'm not mistaking.
youre not mistaken.
But since you are speaking about the vortex of magnetism, there has to be a frequency to that vortex to keep being a vortex of magnetism and not a vortex of light.
There is, and its a phase shift and its quantifiably measurable, especially in LIGHT and biological experimentations.
.pretty mind boggling for me.
Its mind boggling, but its not INSANE nonsense as our current idiot "science" proclaims it to be.
As said, ,,,,...."Mother nature" isnt an insane crack Wh0re,    as GR and QM paint her as.  ;D ;D
joel321
QuoteA vortex is ultimately just an expression of a TETHER,  like that old exercise toy where you whacked a ball on a rubber string that went out and came back.
Birth and death, discharge and charge.............shot and recoil.  Etc.
That makes sense.
Now can you tell me if humans, viruses, animals, galaxies, etc, need to "eat" what does a vortex eat?
QuoteThere is, and its a phase shift and its quantifiably measurable, especially in LIGHT and biological experimentations.
Can you explain the phase shift of this image that you posted http://www.overunity.com/14767/ultimate-proof-of-magnetic-vortex-free-book-and-videos/dlattach/attach/147402/image//
It starts as being geometrical but then it goes crazy in the explosion where there are circles missing. And can you say wich way the circular patterns are moving.
Does a vortex have a curvature?
If it does, what influences a vortex curve?
QuoteAs said, ,,,,...."Mother nature" isnt an insane crack Wh0re,    as GR and QM paint her as
It's still mind boggling to me. But I see a pattern of negative VS positive. As if they both influence each other to become one. I don't know what GR nor QM means tho. Hmmmm although I can kind of picture that the earth is spinning in one directing ONLY due to the part of the magnetic earths vortex having an imbalanced vortex. And that imbalance is what make any spin towards the inside OR spins towards the outside.
Someone has to ask, why is the earth spinning. Heck is the earth spinning clock wise or counter clockwise?
TheoriaApophasis
Quote from: joel321 on February 24, 2015, 01:44:20 AM
isnt that a unique angle of attack in a question.  A vortex is a dual expression of both divergence and convergence,
so your correct question is "what does a vortex SHIT, and what does it EAT"
;D ;D ;D
THAT specific image is not of a phase shift, but the hypotrochoid pattern of the reciprocating hyperboloid which is the magnetic field force.
Ive posted vids of the color phase shift of the rarefaction on the "n pole" and compression on the "s pole", and will most many more using biological experimentations.
its not missing circles, ....its just PART OF a section diagram of the UNFOLDING hypertrochoid expression, like a picture of HALF a car.
pressure mediation, same centrifugal force 'fighting' centripetal convergence,  just as you see in a COIN FUNNEL.
What youre really seeing is a NET TOTAL 0 expression where force lay between two plenums  (or what you would call "rest", ie inertia)
In the "magic faucet" amusement, there is a meaningless faucet seemingly hanging in the air with no source for its water nor its
support; it constantly pours out water, contrary to conventional visual views and logic, it is amusing to watch. Of course, what is
holding up this faucet is a clear plastic tube within which water is being pumped up thru the tube to just inside the faucet, and then
over the edge it flows via gravity outside the clear tube, both occluding the clear tube from view and making it seem that water is only
pouring out, rather than up and into the faucet. All of this is driven by an electrical water pump hidden in the pool, which is not
visible.
In a "magnet", the "pump" driving the magnetism (water), which flows, is the dielectric inertial plane concentrated and focused at
the center (actually its everywhere, but forced to the midpoint by incommensurate magneto-dielectric geometry of opposite fields in a
binding system, the "magnet". As such dielectricity is NOT 'located' at the center.). While in the case of the "magic faucet"
amusement, gravity is causing the resultant convergence back to the pool from which it was pumped, in the case of the "magnet",
convergent return of the 'dielectric field' (i.e. magnetism) is driven by simplex pressure mediation of the reciprocating and "flowing"
divergent radiation that is magnetism resultant from the point non-specific dielectricity either coherent or increased dielectric
capacitance, as present all throughout the physical "magnet".
joel321
Quoteisnt that a unique angle of attack in a question.  A vortex is a dual expression of both divergence and convergence,
Just tell me if the sun in our milky way spins in the opposite direction of the earth planet rotation.
I still have to imagine that a vortex us eating sub-atomic particles are are even being influenced to turn certain way. Like your mind, it's turning along the way how the earth is spinning thousands of miles in the perimeter....not matter what your thoughts are, they are always spinning with the speed of the earths rotation. Which from I can understand is thousand of miles per second. SO, the magnetic vortex cannot be straight in the center....wow now we have vortexes that have curved cones lol.
QuoteTHAT specific image is not of a phase shift, but the hypotrochoid pattern of the reciprocating hyperboloid which is the magnetic field force.
I believe in your vortex, i'm just trying to find it hard to believe that a vortex is a 100% perfect geometrical vortex. That is what i'm getting at...since a vortex also needs to make babies lol, if you can understand what I mean. So a vortex cannot be 100% straight since you have mentioned that the perimeter of earth is spinning thousands of miles per second, I think. So if the vortex of a magnet is also influenced by the spinning of the earth so that makes the vortex "wobble" too....wobbling inside wobbles.
What i'm saying is that is that I believe in vortexes but the vortexes also curve because if they did not, the it would just cancel out. = a vortex vortexes to up, down, left, right, ONLY.
A vortex cannot be 100% straight if the earth is spinning thousands of miles in the perimeter....so your pictures can NOT be all geometrical up or down.
Quotepressure mediation, same centrifugal force 'fighting' centripetal convergence,  just as you see in a COIN FUNNEL.
is the sun spinning the opposite way from the earth?
BTW, I don't get the deep meaning about that "MAGIC FAUCET". An electric pump is just pushing the water up and b;locking it to go down the clear pipe.
What really AMAZES me is how can a solid glass be clear! There is something in front t of our noses that is evading us that we take for granted. A solid "glass" that we can see through it? Which, to me, makes me what to think, what other PHENOMA is there that we cannot detect but only can see through?
Mind boggling to me.
