Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
0 Members and 23 Guests are viewing this topic.
TheoriaApophasis
Quote from: Qwert on February 25, 2015, 11:11:55 AM
but they are still, not moving at all.
It takes a GENUINE IDIOT without equal to think or presume a FIELD of DIVERGENT FORCE, which both DENOTES and CONNOTES MOTION.....
......is "not moving at all"   ;D
Find your teacher(S), and slap the ever-loving shit out of them for producing this mental defect on your behalf
sadang
I run a home experiment with pure silver 99.99% purity in a colloidal form in pure water (0ppm). The goal was to see the movement of silver particle in water under the influence of a magnetic field. Even if it does not bring clear evidence for or against the vortex motion, I thought I have to post it, as I said in a previous message.
Because I did not find a pure distilled water I used what I found, namely a distilled water with 6ppm impurities. For this I thought to use the light from a 5W headlamp or a green 5mW laser.
For this home experiment I used the following setup:
- ~700ml distilled water with 6ppm
- 2 rods of silver 99.99% purity (4N)
- a charger with output of 12v/300mA
- a ferrite magnet of 8x1cm
- a green laser pointer of 5mW
- a headlamp of 5W
Obtained colloidal solution had a concentration of 31ppm, thereby there are 25ppm of silver particles in water, or a concentration of about 25 mg/l. The size of silver particles are in the 0.01 to 0.001 um range.
The magnet was placed under the glass jar, the colloidal solution was stirred in horizontal plane avoiding any rotational stirring, and it was left for 15 minutes so the colloidal silver solution have time to calm and stop any previous movement.
Observations and Interpretation:
- with headlamp did not see any kind of movement, because the light was too diffuse.
- with the laser beam I can see with naked eyes a specific movement, but can't be seen on camera. I'll try again after I'll receive an 100mW green laser.
- the movement seen with the green laser was as some flickers in the water due to reflection from tiny silver particles, and it was fast and from left to right as the beam approach the glass wall (or above the circular arm of the magnet) and slowing as the laser beam goes to the center of the magnet.
- these are personal observations and should be treated as such
profitis
Great work @sadang.is that magnet strong enough? You must use a very strong magnet eg neos.can you make out if thers any orderly movements going on in ther.make sure that the jar is sealed with lid on to avoid cooling evaporation
sadang
Quoteis that magnet strong enough? You must use a very strong magnet eg neos.
Unfortunately that magnet is not so strong, it has about 300Gauss, and a neodymium magnet at this size is too expensive for my pocket. However the moving flickering I've seen with my eyes I interpret as circular movement of the silver particles. It is just a subjective interpretation and not yet provable. Maybe with a more powerful laser or magnet the movement would be more evident. I'll see when will arrive the 100mW green laser head.
profitis
