Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
profitis
Sadang:'Anyway, I would like to know why you consider the magnet has to lower its temperature and the bismuth has to increase it in their interactions?'
Because of the law of conservation of energy.every heat-sink requires a heat-rise somewhere else in the system.let us assume mr apophasis is correct in his infrared photograph and heat is exit-ing the ball,it must also necessitates a removal of heat in the magnet if the magnet is doing work on the ball as he claims.the environment will get heat out the ball and donate heat into the magnet.this is one 2nd law violation hypothesis that could at same time prove mr apohasis correct if tworks.it will mean something is oscillating indeed,something inside the magnet.a chunk gadolinium will do inplace bismuth for this necessary photograph.will apophasis co-operate? If not,why not I say.
profitis
Dingbatjoel:'Porfitis, why does a light follow a light?'
Maybe you have hairs on your hairs.your ball-hairs are moving not the light
TheoriaApophasis
Quote from: profitis on February 26, 2015, 06:33:05 AM
lets ASSUME (rather know) that you miss the entire point.
1. there is NO DIRECT LINK between the object and the magnet.  FIELDS ARE PARTICLE FREE.
2. Denotative field force DIVERGENCE against natures HIGHEST diagmagnetic element (lowest magnetic permeability) causes atomic excitation.
By your insane logic, the sun gets COOLER resultant to foreign bodies accelerating towards same
Youre assuming some form of cooling / heating  CATHODE / ANODE nonsense in your mental fart.
joel321
Quoteive got a finger for you and some others if you want to see it.
LOL...fair enough...and funny to be honest. BUT, but what I was kind of insinuating is that the thumb being the strongest finger of the hand nd the pinky the weakest hence you have a half circle of force. The opposite is the other half of force which you probably figured out = the opposite hand.
The middle finger has not a lot of vortex force lol.....the thumb does so i would rather you give me two thumbs up instead of two middle fingers up...lol.
profitis
Apohasis:'By your insane logic, the sun gets COOLER resultant to foreign bodies accelerating towards same'
For this insult you have enraged me.you are arguing with the premier thermodynamicist of this website.I am now going to proceed to attack your hocus-pocus head-on. It is YOUR hypothesis that the magnet does WORK on the BALL not so.this NECESSITATES a reduction in the temperature of the MAGNET not so
