Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
profitis
Thanks tagor.so now we have a pretty much full pixture of how apophasis-model would work if implemented. All existence is composed of a)bundles of oscillating di-electric circuits and b) vaccuum.the interactions of said bundles giving classic newtonian action-reactions in energy exchange.now there's just one small problem @mr apophasis: heat.what is heat. according to your model energy is vibration or momenta of condensate.but heat is ALSO a photon,an infrared photon.heat has mass.a hot bucket of water weighs slightly more than than a cold bucket of water of equal size due to e=mc2. In other words your di-electric infrared condensates photons is infact capable of conversion into energy momenta and vise versa not so? Here we see e=mc2 in the original meaning of the word where mass and energy are literaly interconverting not so? Infrared photon>enegry momenta/energy momenta>infrared photon.we're adding mass to a bucket of water when we add infrared photons,when we heat it.hot coffee in a glass flask weighs slightly more than cold coffee in the same flask if it were floating in outer space until all momenta is lost via radiation losses not so? Momentum IS mass not so?
profitis
I'm fine-tuning the atomic blast example here for you a bit mr apophasis.
TheoriaApophasis
Quote from: profitis on March 11, 2015, 06:12:24 AM
is ALSO a photon
what photons? they dont exist,
theyre bounding compressions in a Z axis binding transverse circuit (EM/ light), either circular polarization or otherwise dependent upon phase shift.
all EM/Light     is just E and M pistons along a DIELECTRIC CRANKSHAFT
Our modern idiot science says there are pistons, but no crankshaft
The medium and the max rate of induction is C squared.
the very principle of a PROTON exists because a "wave packet" is (almost) exactly like an atom with a dielectric pulse at its center, with transversing EM phenomena.
The so called BS "wave packet" is just a propagating Electromotive circuit of bounding E and M concurrent to the frequency of the perturbation which created the TEM to propagate.
profitis
Apophasis:'the so called BS "wave packet" is just a propagating
propagate.'
Yes but it has mass correct? So an infrared wobbly of a certain high frequency bangs into some black condensate and dissipates its momenta energy into lower frequency vibes.if you were to collect all those dissipated lower-energy  vibes and shove them all together again you would see the bathroom scale weigh exact same as prior to collision ala the atomic blast example.I guess this is why photon up-conversion in certain crystals requires two or more lower enegry photons to come together insync.to conserve MASS
profitis
You will note that its this point of confusion mass/energy and inter-relation thereof is probably where the different models of physics spring forth as it is very largely limited to ones perception or even point-of-view nevermind perception.
